66 Users Online (64 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Help - My render won't export
Wed, Sep 10, 2008 at 11:47:37 AM | Help - My render won't export
timglass
Third time is supposed to be a charm.  Render a 3D view in the Front.  Have rendered it successfully and exported it.  Recently added 3D mass objects and re-rendered it.  Renders fine (1 hour 20 minutes), but when I click export, I get the usual dialog boxes.  Click save and everything seems to have worked - except there's no image in the folder.  The file is 12MB so I can't upload it.
RAC 2009.
Thanks,
Tim
Wed, Sep 10, 2008 at 1:09:11 PM | Help - My render won't export
4 Stars: 203 Votes
Hi, what don't show up? th ALL image or only the 3d-mass objects you added after?
Wed, Sep 10, 2008 at 2:28:23 PM | Help - My render won't export
timglass
The render finishes completely.  The elements I added were a 2' wainscot to the bottom of the wall.  I used the mass solid within Revit.  It shows in the render, and the render completes.  I click export, and I get a save in location dialog. I give it a name, choose the file type (have even tried changing between jpg, png, tiff, and bmp) and click save.  The dialog closes which indicates it's exported and saved the image.  I browse the folder where the image should be - nothing.
Wed, Sep 10, 2008 at 3:06:05 PM | Help - My render won't export
4 Stars: 203 Votes
Hummm... wierd, did you upgrade the "Web Update 20080602_1900" to RAC 2009?
Thu, Dec 18, 2008 at 10:54:53 AM | Help - My render won't export
ementaldesign
ementaldesign Avatar
3 Stars: 2 Votes
I found that it is easier and that I get better quality images from my renders if I actually print the rendering usign Adobe PDF printer. You can go to advanced setting in the printer dialog and bump up the dpi as well. Try also exporting the image to your desktop. Sometimes it can reset the export path.
Mass won't export/import
Sun, Jul 23, 2006 at 2:34:09 AM
Revit MEP 2011 Won't Export dwf/dwg Files
Sat, Oct 29, 2011 at 6:47:44 PM
Revit won't export my electrical fixtures
Thu, May 19, 2011 at 11:24:45 AM
Mullions won't render
Wed, Jun 24, 2009 at 4:09:31 PM
Lights won't turn on for exterior render
Wed, Mar 16, 2016 at 6:03:05 PM
Page generation time: 0.8118
