Forums >> Revit Building >> Tips & Tricks >> Detail Section Placement
I was just wondering if anyone had a clever way to prevent section tags from showing up in all my views. I am nearly done with a CD set and had to do some shaftwall details, now I have to go through all of my plans, sections, elevations, blah blah blah and make sure they do not show up. My first thought are view templates but I would really benefit from a preventative measure to insure I don't ever have to look.
Change the view properties (uncheck "sections" . I've done this plenty of times. You can also change the section element properties so that it will only show up at certain scales. You ma y have a section that you only want to appear on the site plan, but not the floor plan.
Christopher Ganiere, NCARB, LEED AP
www.developmentone.net
Skype: ArchitectCRG |
Chris, That is exactly what I dont want to do, since I am at the point in my project i literally have hundreds of views. When I set a section cut you then have to check every single view that may have a relationship to that specific cut. What I want (and this will go on the wish list) is for sections to have the option that callouts have. The "Show In" parameter.
You don't want to use view templates, but it looks like that is the only option left. Since you have hundreads of views. Modify one view and create a new view template from that view. You can then apply the new template to the others. You will need a new template for each scale.
Edited on: Mon, Sep 15, 2008 at 6:19:30 PM
2D detail item nested to Steel Beam family - Placing level problem |
Fri, Jan 13, 2012 at 12:00:35 AM
plan detail callout in section |
Fri, Mar 29, 2013 at 12:48:11 PM
14
Section Blow up Details |
Tue, Apr 29, 2008 at 4:38:22 PM
link detail drawing from another drafting view in the same project |
Wed, Oct 12, 2011 at 11:14:00 AM
RAC 2009 - detail groups and section detail blow-ups |
Fri, Mar 26, 2010 at 8:50:53 AM
Members: | 2123657 | Objects: | 23215 | Forum Posts: | 152307 | Job Listings: | 3 |
