108 Users Online (105 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Rendering Tab
Tue, Sep 9, 2008 at 12:44:41 PM | Rendering Tab
kkrantz
I have been reading several posts about how to add a sky to my rendering. Everyone says to change the settings under the Rendering Tab. I don't have "settings" under "Rendering". I just have "modify" and "rendering dialog." Does anyone know why that is and/or how I can change that?
(I'm working with Revit Architecture 2009.)
Tue, Sep 9, 2008 at 1:28:01 PM | Rendering Tab
4 Stars: 203 Votes
Hi, if you work with Revit 2008 you have a "Settings" buttom in a rendering tab but now with the 2009 you have right, you only has a "Modify" buttom and "Rendering Dialogue" buttom, see the video: http://screencast.com/t/gN7iBZegYsT
Tue, Sep 9, 2008 at 1:34:22 PM | Rendering Tab
Belinski
4 Stars: 5 Votes
They are reffering to the 'rendering dialogue' tab
Tue, Sep 9, 2008 at 2:11:22 PM | Rendering Tab
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
Just render with the Mental Ray sky, then save the image as a .png or .tiff, this will filter out the alpha channel (alpha = MR sky)
Then just create a drafting view and insert your sky image and size it, then insert your rendered png over the sky.
Tue, Sep 9, 2008 at 2:48:45 PM | Rendering Tab
kkrantz
Where do I find the "mental ray" sky option?
Tue, Sep 9, 2008 at 3:05:17 PM | Rendering Tab
4 Stars: 203 Votes
"Where do I find the "mental ray" sky option?" - in the same "Render Dialogue" you have "Background>Style", see picture attached...., you also can (before goes to rendering) go to the TOP menu and in "Settings-Sun and Shadows Settings" and in there you can change the settings to "By Date, Time and Place" to create the "exact" shadows projection in your model but i think you must read the HELP tutorials...
Edited on: Tue, Sep 9, 2008 at 3:46:29 PM
Question on rendering?
Fri, May 8, 2009 at 7:07:18 PM
Rendering Design Tab
Thu, Jan 29, 2009 at 12:38:40 PM
Elevation Tab
Mon, Sep 19, 2016 at 10:13:49 AM
Render on revit
Thu, Mar 9, 2006 at 6:45:07 PM
Cannot access Forms Tab or Detail Sketch Tab
Thu, Mar 21, 2013 at 8:14:56 AM
Page generation time: 0.4635
