39 Users Online (37 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> raster image issue when exporting titleblocks to dwg / autocad
Mon, Sep 8, 2008 at 2:25:15 PM | raster image issue when exporting titleblocks to dwg / autocad
tarahdb
I would like to be able to export a title block from Revit (2009 version), for use by consultants who work in AutoCAD. I can do this by either A) creating a blank sheet in the project and exporting it, or B) exporting the titleblock directly from the family file and then entering the appropriate info for project title, address, etc Cryingsee attached files of Revit title block and exported DWG version).
 The problem is, no matter which way I do it any raster images inserted in the title block (namely, the firm logo) have a box drawn around them when exported. Is there a setting I can change so it won't put a box around the logo? I can't easily fix this in AutoCAD by deleting just the box because it deletes the entire image, and if I try to explode it the image disappears. Any help is greatly appreciated.
Mon, Sep 8, 2008 at 2:33:12 PM | raster image issue when exporting titleblocks to dwg / autocad
This I believe is an AutoCAD setting.  Imageborder
Mon, Sep 8, 2008 at 5:44:07 PM | raster image issue when exporting titleblocks to dwg / autocad
timbo89
timbo89 Avatar
4 Stars: 5 Votes
Open the Autocad drawing, type TFRAMES and it should disappear
  • Core 2 Duo E8400 3ghz
  • 756mb Nvidia 9600GSO 256bit
  • 6gb Kingston RAM 800mz DDR2
  • Windows XP Service Pack 3 32-bit
Tue, Sep 9, 2008 at 12:12:42 PM | raster image issue when exporting titleblocks to dwg / autocad
tarahdb
Tframes worked.  thanks so much, that's exactly what I was looking for!
PDF Raster image as a super imposed backgroud
Sun, Nov 7, 2010 at 8:46:58 PM
Exporting Layouts in to AutoCAD / piping issue...
Thu, Sep 4, 2008 at 4:12:10 PM
Raster Image display
Fri, Oct 10, 2008 at 6:08:26 AM
exporting to AutoCad
Thu, Jun 20, 2013 at 1:24:08 PM
Exporting Revit 2009 (.rvt) to AutoCAD (.dwg)
Mon, Jul 13, 2009 at 3:55:27 PM
Page generation time: 13.0331
