54 Users Online (53 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Black Screen Problems
Mon, Sep 8, 2008 at 11:18:12 AM | Black Screen Problems
Predklaw
Hi all, as can be seen in the attached image we are having a little trouble with Revit Architecture 2009. When we select the standard 3D view in this model the screen background is black instead of white; however, our background option is not set to invert colors. All remaining 3d views (ones we have created and named) all show as the standard white background. Also we have tried deleting the 3D view and re-creating it but the background on this one view always shows up black.
Any help on resolving this issue would be greatly appreciated as it is not killing the model just extremely frustrating.
Thanks
Mon, Sep 8, 2008 at 12:35:38 PM | Black Screen Problems
4 Stars: 201 Votes
Hell, it's wierd, i never see this issue before, did you upgrade the "Web Update 20080602_1900"? Any other 3D View it's like this or just this 3D view is with this background?
Mon, Sep 8, 2008 at 1:01:08 PM | Black Screen Problems
Predklaw
This problem has been resolved, thanks for your help. It turns out that the problem was a bad ADAC linked file, once the file was removed the problem went away. Still an odd glitch in the system.
Tue, Jan 12, 2010 at 8:24:33 PM | Black Screen Problems
Blakey
Blakey Avatar
I am having a "Black Screen" issue as well. When dimensioning in a chain none of the dimension values show up until the dimension process is completed and the ESC key pressed a couple of times. I have attaced an image of how the dimensions appear sometimes.  ???? I know it's not a major issue but at the same time very annoying, especially when it works fine on another machine in the office.
HELP!~ Black Screen Patch
Sat, Jun 8, 2024 at 3:08:23 AM
black screen and unfinished renders
Tue, Apr 21, 2009 at 7:28:17 PM
Black annotations on black screen
Mon, Jun 20, 2016 at 2:18:39 PM
Black Screen Bug
Fri, Oct 16, 2009 at 1:13:17 AM
Revit 2009 Rendering Problem(Black screen) [ 1 2 ]
Mon, Apr 1, 2013 at 2:45:28 PM
27
Page generation time: 0.4780
