46 Users Online (44 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Tips & Tricks >> Bulleted Text
Mon, Sep 8, 2008 at 6:57:28 AM | Bulleted Text
BigD
BigD Avatar
1 Stars: 1 Votes
Found this in a Cadalyst Tip:
Paul Hildebrandt shared this tip for Revit converts: "If you select a few lines of text in a multiline text object and hit Ctrl + Shift + L, Revit will create a bulleted list for you. If you keep pressing this key combination, you will cycle through multiple list styles and back to normal text."
Works great!  Except . . . whenever I click outside the text box, the bullets go away. Sad  Any ideas on how to make the process work better?
Note: I also found that:
Ctrl+Shift+A  -  toggles from lowercase to uppercase
Mon, Sep 8, 2008 at 8:42:48 AM | Bulleted Text
I believe these might be text edited features that are not yet functional or supported because they are not in the help menu that I can see.  Looks like they will be a big help though.  This is the same in 2008 and 2009.
Mon, Sep 8, 2008 at 3:09:26 PM | Bulleted Text
BigD
BigD Avatar
1 Stars: 1 Votes
This came in a Cadalyst email newsletter today.
Bummer.
Follow-up: Bullet Lists in RevitSeveral readers notified us about a glitch in the tip regarding making bullet lists in Revit in the August 25 edition. Some pointed out that the tip works fine while you are in the text, but as soon as you click outside the text, your bullets disappear. We haven't forgotten; the Tip Patrol is still looking for a fix for this. If you know how to avert this problem, please share the secret with us and we'll pass it on.
Fri, Apr 24, 2009 at 7:07:20 PM | Bulleted Text
jaff
3 Stars: 2 Votes
This text futures are not supported in RAC2010. I was hoping Autodesk will do something about it but all they change was the user interface which to me is cumbersome I had to readjust to the way it is now. It is making my work flow slower. I am frustrated because Autodesk just did cosmetic stuff to the software and forgot to improve the funcitionality of it.
Tue, Mar 9, 2010 at 1:47:09 PM | jaff
pepsiqueen
pepsiqueen Avatar
Quoting jaff from 2009-04-24 19:07:19
"This text futures are not supported in RAC2010. I was hoping Autodesk will do something about it but all they change was the user interface which to me is cumbersome I had to readjust to the way it is now. It is making my work flow slower. I am frustrated because Autodesk just did cosmetic stuff to the software and forgot to improve the funcitionality of it
  I'm not sure it this text will appear withing the quote; but this DOES work with 2010. awesome. now if only the UI showed it as an option.
I'd rather be riding at whistler. or highland. thats good too.
Text formatting (bullets & indents)
Wed, Jun 11, 2008 at 8:49:16 PM
Text Formatting
Thu, Oct 25, 2007 at 11:12:30 AM
Changing Text Size in a text box
Thu, Aug 6, 2009 at 6:41:14 AM
Dimension Text [ 1 2 ]
Mon, Jul 7, 2008 at 3:20:00 PM
16
Linking CAD - Text Sheets
Wed, Mar 18, 2009 at 5:42:16 PM
Page generation time: 1.0035
