108 Users Online (104 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Whoop I minimized RAC2009! - Is it still rendering my walkthrough?
Fri, Sep 5, 2008 at 4:45:48 PM | Whoops I minimized RAC2009! - Is it still rendering my walkthrough?
KevinKernaghan
While RAC09 was busy doing a hidden-line 1:08 30fps walkthrough .avi (using the Microsoft codec) through about a 100MB file (a 4-story dormitory complex), I accidentally hit the "Show Desktop" button on the Taskbar.
Now I can't get the window to restore itself and I don't know if it has ceased this operation, if there is a dialog I need to answer to get the video to complete itself or if everything is fine and it might be done animating by the time I leave work in an hour.  Has this happened to anybody else?  What were the results?  I saved immediately beforehand so I'm not worried about losing any information, I just know it has been doing this for an hour and a half so far and I'd like to not leave my computer on over the weekend.
Thanks and it's a pleasure to meet you all,
 Kevin
Edited on: Fri, Sep 5, 2008 at 4:46:40 PM
Fri, Sep 5, 2008 at 5:41:33 PM | Whoop I minimized RAC2009! - Is it still rendering my walkthrough?
KevinKernaghan
Double whoops!  Turns out the program showed up about 3 minutes after I started the thread.  Persistence pays off. Of course, now I have to do it again, because compression was set too low, but eh.
Mon, Sep 8, 2008 at 7:39:33 AM | Whoop I minimized RAC2009! - Is it still rendering my walkthrough?
tim123
4 Stars: 19 Votes
You can also tell if Revit is rendering by looking at the performance tab of the task bar - if it is showing activity and you're not doing anything else, it should be Revit working away.
Walkthrough
Thu, Sep 24, 2009 at 8:24:31 AM
Walkthrough rendering stops [ 1 2 ]
Mon, Feb 22, 2010 at 4:30:51 AM
17
Distributed Rendering
Mon, Aug 17, 2009 at 2:02:38 PM
Walkthrough Export is very slow
Fri, Feb 13, 2009 at 2:44:46 PM
Rendering a Walkthrough
Fri, May 5, 2006 at 9:42:55 AM
Page generation time: 1.5855
