41 Users Online (39 Members):
Forums >> Revit Building >> Technical Support >> Lighting fixtures not against exterior wall face
20 Posts No Rating |
I am working in Revit Architecture 2009. I have a lighting fixture family in many places on the exterior of the building. Some of the lights are fixed to the exterior wall face (which I would like), but many are either sunk in too far into the wall or are floating out away from the wall. I'm not sure what the setting is that is causing this. Any help would be much appreciated.
hi, depends like the family was created, you can create lighting fixtures ceiling based, wall based, or "free" based when you can put your lights in to the ground or in stairs and so one, so you can edit the family of one of that lights "in too far into the wall or are floating out away from the wall" and check the parameters and the family category...
Hi, in your lighting fixture family select the wall and go to its properties, and edit its structure to change the overall thickness of the wall and then OK out of the dialog boxes. I expect you'll either get constraint errors or the wall will change thicknesses but you lighting fixture won't move because its not constrained to the wall properly. Its much easier to nest families into the hosted templates as they are much easier to constrain. Check out my blog as I'm pretty sure I've got some more in depth information on there for you. Cheers.
Regards,
Chris.
Thank you both for your help. I figured I should change the wall thickness. My main concern was that I would fix the same exterior lighting fixture to different wall types, thus any one wall thickness wouldn't suffice for all walls. I'm going to try nesting families in the future. Thanks!
Laura11, The reason why Mr Spot suggested you change the wall thickness in the family was to discover what was wrong in the family. It will not fix your problems.
Oh. I found that it did since most of the walls are very similar. I need to check out his blog later. We're trying to submit for DRB asap so I will definitely change them in the future. (I just need light to be rendering from the right places). Thank you for the warning.
How to show lighting fixtures on floor plan |
Mon, Nov 6, 2006 at 10:15:38 PM
create a new lighting fixtures |
Fri, Aug 15, 2008 at 10:54:54 AM
interior lighting for exterior rendering [ 1 2 ] |
Thu, Feb 11, 2016 at 2:03:04 PM
16
Lighting fixture problems |
Wed, May 10, 2017 at 9:52:09 AM
13
Lighting Fixtures |
Thu, Apr 24, 2014 at 6:13:26 AM
Members: | 2022391 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
