Forums >> Revit Building >> Technical Support >> Ceiling Height in Room Tag?
2 Posts No Rating |
I'm trying to make Room Tag that has Ceiling Height as well. In the room schedule, I could create ceiling height by using Volume/Area formula, but can I put this formula in the tag some how, so it will appear when I place the tag? If yes, how can I do that???
No - no formulae in tags.
use spot elevations - these will update dynamicaly...
2 Posts No Rating |
WWHub: Thank you for your information. I thought I can add formula by using "Family Types". psymon: I don't know how/where to use spot elevation because I have never done spot elevations, but I'll try. Thank you for your input!
I would try adding the height parameter to your room scedule as a shared parameter then add it to the tag? I don't know if it would work but it's worth a shot eh?
" would try adding the height parameter to your room scedule as a shared parameter then add it to the tag". This method will not automatically update and will only show a manually entered value Spot elevations can be made relative to a level and thus can show for example CL + 2700.
Room Name w/ manually entered Ceiling Height |
Mon, Jan 19, 2009 at 3:50:31 PM
How can I add clear Height (floor to bottom of slab above) in a Room Tag? |
Sun, Aug 21, 2016 at 3:08:15 AM
Ceiling height in Room Tag |
Thu, Jan 22, 2009 at 3:00:38 PM
Room Tag + Ceiling Tag Hybrid |
Wed, Jan 21, 2009 at 8:40:09 PM
Ceiling height in Room Schedule |
Sun, Apr 5, 2009 at 12:44:48 PM
Members: | 2098476 | Objects: | 23169 | Forum Posts: | 152292 | Job Listings: | 3 |
