45 Users Online (43 Members):
Forums >> Revit Building >> Technical Support >> editing walls
50 Posts No Rating |
i have a composite wall with a brick veneer. in a section view i would want to be able to extend the brick veneer to meet the foundation footing. i have not found any means of doing this in the edit assembly dialog box
could anyone provide a step by step approach of achieving this.
thanks
Select a composite wall and go to its properties,
Click edit/New
Then edit structure.
Turn on the preview and change it to section as opposed to floor plan.
Select modify and pick the bottom edge of the brickwork. A padlock should appear. Unlock it.
Now click okay, until all dialogue boxes are gone.
Select one of your brick veneer walls and go to its properties, you should now have a parameter for bottom extension distance. Enter in a negative value for how far you wish the brickwork to extend down...
There you go...
HTH.
thx a bunch , spotty
Editing how walls are attached to floors |
Fri, Aug 1, 2014 at 7:37:38 AM
editing group.... |
Wed, Jul 26, 2006 at 2:45:37 AM
Editing Parameters of Walls embedded within Groups (Bug?) |
Fri, Dec 1, 2006 at 11:58:48 AM
Editing Keynotes |
Tue, Sep 14, 2010 at 9:47:45 AM
Editing request |
Tue, Jun 29, 2021 at 2:20:20 AM
Members: | 2022396 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
