29 Users Online (28 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> deleting dwg file
Sat, Apr 23, 2005 at 5:40:59 PM | deleting dwg file
yoiyoi
how do i delete a dwg file which i imported into a revit project?
Sun, Apr 24, 2005 at 3:48:30 AM | RE: deleting dwg file
Xane
Easy, select it and delete it, why, it isn't work.
Tue, Apr 26, 2005 at 10:38:28 PM | RE: deleting dwg file
yoiyoi
when i select and delete the imported files still show up when i go to the visibility/graphic override table in the dxg/dgn categories i would like to completely remove it from the revit project
Tue, Apr 26, 2005 at 10:57:04 PM | RE: deleting dwg file
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
It will disappear from this section only when all instances of the dwg are removed from the project. I assume it was imported as current view only? Check to see if it hasn't been copied to other views and just turned off... HTH.
Wed, Apr 27, 2005 at 1:22:12 AM | RE: deleting dwg file
yoiyoi
ok i finally located the imported file ( i had set it to background) now i imported the dwg file as a block and would like to change the line type to hidden without exploding it . how do i do that? i tried using override in the visibility dialog box to no avail any help, any one?
Wed, Apr 27, 2005 at 1:40:16 AM | RE: deleting dwg file
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
You'd have to make sure the linetype in the dwg file is set bylayer, as otherwise you wouldn't be able to override it in revit... Other option is to use the pick command and pick dashed lines for these then turn off or delete the unwanted layers from the dwg... HTH.
Thu, Apr 28, 2005 at 1:42:40 PM | RE: deleting dwg file
yoiyoi
Mr.Spot, Tried your suggestions on making the dwg lines by layer in autocad and even using override in visibility dialog box and still can't get my imported dwg to show hidden line as originally drawn in autocad. haven't tried the pick option though. where do i find pick command? thanks
Thu, Apr 28, 2005 at 10:20:25 PM | RE: deleting dwg file
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Depending on your requirements, either use detail lines or model lines then change the draw option to pick (the picture of the arrow). HTH.
Fill Regions not deleting
Thu, Oct 8, 2020 at 3:52:54 PM
Cant import .dwg file correctly.
Tue, Jun 25, 2013 at 7:24:07 AM
Converting to DWG file type.
Fri, Apr 2, 2004 at 12:01:13 PM
Export to dwg problem - I want it all in 1 file :) - please heeeelp
Wed, Jan 23, 2008 at 4:36:53 AM
Section through a family object and imported dwg file
Fri, Mar 26, 2010 at 12:41:24 PM
Page generation time: 0.7657
