Forums >> Revit Building >> Technical Support >> Window with different head height on inside and outside
5 Posts No Rating |
We're working on a historic brick building. The windows have a brick arch on the outside, but a square top on the inside. The inside head is level with the TOP of the exterior arch (the brick arch covers over part of the window sash.) Any suggestions on how to model this in a window family? Working in Revit 2009. Thanks, Andrew Blyholder
Hi, do you have some photos for exterior and interior window????
5 Posts No Rating |
Pictures attached.
Hi, create the window Family with Trim like outside view and in the inside create the trim around with the net wireframe...
Edited on: Wed, Sep 3, 2008 at 1:42:31 PM
Setting Window Head Height |
Fri, Feb 24, 2017 at 12:16:50 AM
14
head height of window |
Thu, Nov 3, 2005 at 5:19:15 PM
Actual Window Head height |
Thu, Jun 7, 2007 at 5:44:30 PM
window is 1" off of head height |
Sat, Aug 17, 2019 at 1:15:54 PM
Pella Window Head Height Schedule Problem |
Mon, Mar 12, 2007 at 5:42:22 PM
Members: | 2100905 | Objects: | 23171 | Forum Posts: | 152292 | Job Listings: | 3 |
