80 Users Online (79 Members):
Forums >> Revit Building >> Technical Support >> Revit 2008 Rendering sweep
69 Posts No Rating |
I have a sweep that has a material (wood, walnut) applied to it. for some reason that sweep will not render the walnut on the rounded edges, any suggestions?
The material glossiness is at 10.
That sweep it's one piece? or you create that in 2 parts for example?
Edited on: Tue, Sep 2, 2008 at 5:09:44 PM
It is one sweep with two profiles, a top and bottom rail
You mean "Solid Swept Blend"?, NO, sorry, you work with 2008, so you don't have "Solid Swept Blend", but with a "Sweep" you only can put a "Path" and one "Profile", so... can you put this solid to download to i take a look?
Edited on: Tue, Sep 2, 2008 at 5:55:22 PM
Going from Rendering in RA 2008 to Rendering in RA 2009 |
Mon, May 11, 2009 at 4:32:50 PM
Looking for Rendering Suggestions on a Revit 2008 Accurender Rendering.......... |
Wed, Nov 4, 2009 at 4:41:36 PM
Revit 2008 wall sweep in door |
Thu, Aug 21, 2008 at 1:53:14 PM
How to Load a Wall sweep type |
Mon, Jun 9, 2008 at 12:42:29 PM
Sweep Problem at roof! |
Sat, Feb 16, 2008 at 8:30:31 AM
Members: | 2016954 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
