86 Users Online (85 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Plywood under wall
Tue, Sep 2, 2008 at 3:14:59 PM | Plywood under wall
jarosa
jarosa Avatar
4 Stars: 5 Votes
What do i have to do to get the plywood on my floor system to extend under the wall? This is something I have not seen before. What did i do different?
RAC 2009
thanks,
John
Tue, Sep 2, 2008 at 3:55:40 PM | Plywood under wall
4 Stars: 203 Votes
Well, or i create-in-place that piece or if you don't want that in 3D, well, create a "Fill Region" with that pattern and locked to the slab....
Wed, Sep 3, 2008 at 5:57:54 AM | Plywood under wall
jarosa
jarosa Avatar
4 Stars: 5 Votes
I checked other projects. The wall does not cut the plywood like it does here.
Wed, Sep 3, 2008 at 6:04:11 AM | Plywood under wall
jarosa
jarosa Avatar
4 Stars: 5 Votes
Here's how i fixed it. I pulled the exterior sheathing/finish above the floor level. Aligned the bottom of the wall to that then reset the bottom of the wall to the top of plywood. Then pulled the exterior down to the correct level. Must have had something to do when the floor originally cut the wall.
Wed, Sep 3, 2008 at 7:39:52 AM | Plywood under wall
tim123
4 Stars: 19 Votes
This can be done with the priorities of the elements, which it seems you have correct.  You probable could have corrected the problem with the 'Join Geometry' command, if the wall and floor became detached.  You can also modify elements using the cut profile command.
4' x 8' plywood representatiion in Revit (3d view)
Wed, Feb 10, 2010 at 7:42:33 AM
plywood hatch
Mon, Oct 29, 2007 at 10:52:55 AM
Custom Rafter Cut for plumb plywood and square standing seam
Sun, Dec 15, 2013 at 10:26:27 AM
plywood
Sat, Feb 12, 2005 at 5:01:50 PM
vertical plywood
Fri, Nov 25, 2011 at 8:26:44 AM
12
Page generation time: 0.9817
