33 Users Online (32 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Why won't my Filled Regions print?
Tue, Sep 2, 2008 at 2:03:15 PM | Why won't my Filled Regions print?
Coffeefiend
Good afternoon all,
I'm working on a project that contains some CMU columns. Rather than go into great detail with the column type under the parameters tab, I've modeled the columns as concrete and then have overlaid a Filled Region of CMU hatch on top of the column. It looks fun on the screen, but when I print it, the Filled Region dosn't print. This is also happening on other sheets where I've used a Filled Region. How do I make my Filled Region print? I'm using Revit 2009. Thanks.
Tue, Sep 2, 2008 at 2:36:28 PM | Why won't my Filled Regions print?
4 Stars: 203 Votes
Hi, when you pick in your "Filled Region" you pick in top menu, "Bring to Front" or "Send to Back"? Are you print in "Vector Processing" or "Raster Processing"?
Tue, Sep 2, 2008 at 2:48:00 PM | Why won't my Filled Regions print?
Coffeefiend
I have been using Vector processing with my print jobs. Will this make a difference?
Tue, Sep 2, 2008 at 3:16:12 PM | Why won't my Filled Regions print?
4 Stars: 203 Votes
Did you try?????
Tue, Sep 2, 2008 at 3:22:34 PM | Why won't my Filled Regions print?
Coffeefiend
Edit: Should this make a difference? Because it didn't.
Tue, Sep 2, 2008 at 3:38:22 PM | Why won't my Filled Regions print?
4 Stars: 203 Votes
Sometimes make a different when you print in Vector or Raster, i did an example like your and print in the 2 ways and appears in the 2 prints, so in this case don't make difference....
filled regions...
Sat, Jun 13, 2009 at 4:48:38 PM
Filled Regions on an elevation
Wed, May 25, 2005 at 1:35:38 PM
FILLED REGIONS EXPORTED TO AUTOCAD
Thu, Nov 6, 2008 at 4:45:16 PM
Chaning the ouline line style for filled regions
Thu, Jul 19, 2007 at 6:31:48 PM
Masking and filled regions dont cover dimensions and tags??
Wed, Apr 9, 2008 at 11:12:17 AM
Page generation time: 3.6432
