66 Users Online (65 Members):
Forums >> Revit Building >> Technical Support >> Window family that cuts walls?
3 Posts No Rating |
Is there any way to create a window family with a void or opening that cuts walls when placed in a project? Ex: You have two walls one in front of the other, and when you place the window in one of the walls it creates an opening in the other wall directly across from the window?
you have to use join geometry and join the two walls and the window will cut both walls. HTH
Wall Sweep Overlaps window frames and cuts (some not all) |
Mon, Jun 22, 2015 at 8:09:40 AM
Revit 2009 - window family cuts thru some walls but not others? |
Tue, Oct 13, 2009 at 2:08:34 PM
Wall Sweep only cuts out window not trim |
Mon, Aug 18, 2014 at 10:34:16 PM
Void extrusion family visibility |
Fri, Apr 22, 2022 at 7:57:52 AM
Windows in leaning walls |
Thu, Aug 11, 2011 at 9:49:46 PM
Members: | 2056897 | Objects: | 23074 | Forum Posts: | 152249 | Job Listings: | 3 |
