53 Users Online (50 Members):
Forums >> Revit Building >> Technical Support >> Stair Visibility - Revit 2008
3 Posts No Rating |
I have a stair that runs from level 1 to level 2, and my issue is that my 2nd. floor plan shows the stair below the cut line. I have ussed a view region to manipulate the depth of the view in this area (so I don't see the bottom of the stair); but it doesn't seem to be working for me. I also checked that the floor was not set to transparent. Any ideas of why I can not turn the bottom of the stairs off? (please see attach.) Thanks in advance. TW
3 Posts No Rating |
Found the answer.. I had changed my view to be wireframe.
![will2play Avatar](user_avatar/77288.jpg)
I thought you may want to know I’m presenting on Revit Stairs and Railings during this week’s “Rockstar Hour” Learning Objective: Learn how Revit creates Stairs, both the basic and the advanced concepts. See how Revit Creates Railings and uses Rail Baluster Families. Not for the faint of heart, this one is going to be intense. The “Rockstar Hour” is a free hour of Revit training. Every week I come up with an hour long presentation on some issue or concept I’ve helped one of my clients with. I’ll show my screen and present the good, bad and ugly side of the problem. Including the concepts behind the tools, the process using the tools and key terminology. The Web-base training is archived for you to at your convenience until the following weeks webinar is posted. Join the meeting here. https://www1.gotomeeting.com/register/353233504 Rockstar Hour: 9:30 AM – 10:30 AM PST every Wednesday Hope to see you there, Will Harris www.will2play.com
www.will2play.com |
Stair Visibility Question in 2008 |
Sat, Sep 1, 2007 at 1:39:42 PM
Stair Visibility Issues |
Fri, Jun 7, 2013 at 8:58:58 AM
14
Stair visibility issue |
Sat, Jan 5, 2013 at 3:19:19 PM
Stair visibility and room tags |
Thu, Dec 10, 2009 at 9:57:35 AM
stair constraint issues - new user - revit 2008 |
Wed, Mar 26, 2008 at 1:50:54 PM
Members: | 2022326 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
