Forums >> Revit Building >> Technical Support >> curtin walls to windows....
hi can someone tell me how to convert curtin walls into windows? or get them to tag and show up in the window schedule as windows? im using revit 2009 thanks.
Hi, you cannot "convert" curtain walls to windows. Windows are external family types, curtain walls are system families. That said, what you need to do is make a curtain wall window family. File > New > Family > Pick the "Metric/imperial-Window-Curtain wall " family. Make a frameless glass panel and load it into your project/template In your project/template, make a new family type and use the panel family you have just created. It will tag using the window tag and schedule as a window (one long window, but still a window) If you want to convert one you have already created, swap-out the panel type in the family with the new one. HTH
2 Posts No Rating |
You can't convert them. Curtain walls are walls. If you need windows, then you have to create a window family that could have a grid structure with various family embeds -> advanced family modeling. Have fun....
A window can be created from curtain walls, see the tutorials of Reveit Arch 2009, "Creating an Entrance" where a door is created from curtain walls, even I myself created a window with the same method
Chirag C. Pawar Cad Solution Application Senior Engineer KLGSystel Ltd. India 301, Pujit Plaza, Plot No. 67,Sector 11, CBD Belapur,Navi Mumbai - 400614, Maharashtra, India.Tel .: +91 22 409 16777. Extn. - 718Fax .: +91 22 275 76461.Mob .: +91 99 698 66851.Email.: chiragp@klgsystel.com Web .: www.klgsystel.com |
Curtin Walls |
Tue, Aug 16, 2005 at 11:12:26 AM
Glass Rendering Bug |
Mon, Apr 19, 2010 at 12:46:54 PM
Can only square panels in curtain walls be converted to windows? |
Wed, May 16, 2012 at 2:22:02 PM
Can't figure it out, Windows are not cutting my walls |
Fri, Apr 30, 2010 at 12:39:17 PM
Windows and Furred out Walls |
Wed, Oct 14, 2009 at 7:47:12 AM
Members: | 2099164 | Objects: | 23170 | Forum Posts: | 152292 | Job Listings: | 3 |
