63 Users Online (62 Members):
Forums >> Revit Structure >> Technical Support >> Thickened Slab Edge not displaying correctly.
2 Posts No Rating |
I have a problem with my thickened slab edges not displaying correctly, and showing two hidden lines. i have added the two lines from Bim and Beam: [Graphics]HiddenSlabEdge=All with no luck. Is there something else i should try?
Hi, can you be more specific? Some screen shots help to see what are you trying to do.... What version of Revit you use?
2 Posts No Rating |
Typhoon, thanks for the quick reply. I was speaking of the problem associated with slab edges found at Bim and Beam's website here: http://bimandbeam.typepad.com/bim_beam/2008/05/slab-edge-hidde.html. It seems the default (only) behavior is to show two hidden lines shown in their example. Also, I am running Revit Structure 2009. Thanks for the help.
OHHH, BIM and BEAM site... when you post something, please tell the version you are using (working) and clarify the problem.... sorry but i don't work with structural and i don't have the version.... maybe someone else could help you in this situation.... REVIT STRUCTURAL USERS???????
2 Posts No Rating |
Make sure the MODEL GRAPHICS STYLE button has "Hidden Line" checked and NOT Wireframe. See if that works....
2 Thickened Slab Edges in ONE Foundation Slab |
Mon, Jun 6, 2011 at 12:13:35 PM
Modeling thickened slab strip under bearing walls |
Thu, Feb 5, 2015 at 1:13:00 PM
Thickened slab edge |
Sat, Jan 28, 2012 at 4:57:49 AM
Creating slab edge... |
Tue, Nov 4, 2008 at 3:36:02 PM
Thickened Slab Not Cutting Floor Line Out |
Wed, Dec 28, 2011 at 7:54:13 AM
Members: | 2017179 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
