Forums >> Revit Structure >> Technical Support >> title bar
The title bar (ie. the circle with the line, that has the title of the individual view, and the scale ) revit 2009. I want to edit the length of the line of the title bar element, the tutorial says I can select it and then use the blue grip to lenthen it...but when i select the title bar, it only turns red, no grips to grab onto. is there a show grips command? MIchael
When you pick in the Title bar appears in red color but also you have a blue circle in the end of the line (left and right), where you can pick an drag...
you must select the view itself, not the title. have a look http://screencast.com/t/iuPaehuA
GOt it thanks a lot!
How to modify/ customise title bar on sheet? |
Fri, Aug 19, 2011 at 6:56:54 AM
JUMPING UI BAR |
Mon, Nov 22, 2010 at 1:12:34 PM
How to link a Revision Schedule on Title sheet with Title Block |
Fri, Jan 11, 2013 at 7:26:27 AM
Bar top... |
Mon, Feb 8, 2010 at 9:19:41 AM
Title Block - How do I insert a drawing title? |
Fri, Apr 20, 2012 at 12:18:44 PM
Members: | 2098140 | Objects: | 23164 | Forum Posts: | 152291 | Job Listings: | 3 |
