Forums >> Revit Structure >> Technical Support >> installation error
2 Posts No Rating |
I am getting error code 1601 when trying to install autocad2009revits110sp1, can anyone help
Do you try to install from CD or you download the file from Autodesk Web Site??? (if Download what's the adress)
2 Posts No Rating |
Downloaded from the recommended Autodesk site, I cannot find the address but the filename is "autocad2009revits110sp1"
Well, from Autodesk this is the site: http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=11017599 but i don't see that name, if youick in :"Web Update Enhancement List" you will see "Web Update 1 build (20080602_1900)" it's the Only SP to RAC 2009, there is other to Revit SUITE....
if your are in the United States, then that is not the correct installation file for Revit. try this site http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=9262388
REVIT MEP 2012: Installation problem-Error 2343.Specified path is empty. |
Fri, Apr 29, 2011 at 7:30:52 PM
Cabinet Files Installation Error while installing RAC 2008 |
Sat, Mar 22, 2008 at 1:49:14 AM
maxwell installation error!!!!! sos |
Wed, Aug 20, 2014 at 3:56:24 PM
13
Installation Problems |
Workflow & Implementation >> Chameleon
Mon, Jan 14, 2013 at 12:07:31 PM
Revit 2013 installation problem |
Thu, Feb 28, 2013 at 9:23:04 AM
Members: | 2101679 | Objects: | 23173 | Forum Posts: | 152294 | Job Listings: | 3 |
