Forums >> Revit Structure >> Technical Support >> Extruded Family appearance on plans
44 Posts No Rating |
Is there a way to make an extruded family show up as a single line on framing plans? I have created some wood trusses families by creating extrusions. When I put them on the plan, you see the entire member (i.e. the 1.5" width for a 2x4 roof truss or 3.5" width for a 2x4 floor tuss) and also see the web members. I know for bar joist families they will show up as lines.
When you create the family (or now edit the family) you can control the visibilty of what you see in "Corse, medium and Fine" mode....
Thanks, but how would you go about doing that? Sorry but I am very new to Revit.
Wait for the video.... This is the Video: http://screencast.com/t/N2boqEfA0E9 Give me a feed back if this is what do you need...
Edited on: Wed, Aug 27, 2008 at 3:52:11 PM
I followed your steps and now have the model lines showing on the plan like I wanted. However, the truss lines are still showing up. I have turned off everything except Analytical Model in VG.
And in the family you don't create any line in the truss? because if you turn off (in VG) ALL except Analytical Model, ONLY the analitical model lines must show up, but edit the family and select the extrusions of what you want and in "Visibility" uncheck "Medium and Fine" so, only in COARSE Mode you can see the elements, if in the proj. you change the view plan for "Medium or Fine" the elem. don't show....
That fixes my problem with them showing up on the plan, but in section cuts I need to see the trusses in Medium or Fine".
You can control that in the "Visibility", you have the parameters from "Plan, Cut...." - "coarse, Medium...", so....
Alter 2d appearance of Family |
Tue, Feb 10, 2009 at 9:50:47 PM
Revit 2013: Family Materials Graphics vs Appearance |
Wed, Mar 20, 2013 at 7:38:52 AM
angling ends of an extruded shape |
Sat, Nov 5, 2005 at 12:55:05 AM
11
Material Appearance in Revit 2019 |
Tue, Apr 28, 2020 at 10:44:51 AM
Extruded roof - surface pattern displaying incorrect |
Wed, Sep 8, 2010 at 10:00:11 AM
Members: | 2017094 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
