28 Users Online (27 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Help! Can't seem to find how to add new roof sweep profile.
Wed, Aug 27, 2008 at 8:33:43 AM | Help! Can't seem to find how to add new roof sweep profile.
Hogmodo
Hogmodo Avatar
3.5 Stars: 6 Votes
Went through the Revit help topics and Tatjana's Mastering Revit Architecture book and have added new .rfa profile and .rft families to the project.  The family tree shows them being added but they aren't availible when I try to get the roof to host the sweep.  There is some little trick that I am missing.  Help!
Wed, Aug 27, 2008 at 8:45:12 AM | Help! Can't seem to find how to add new roof sweep profile.
Just because the profile is there doesn't mean it's available to you yet.  You have to set that under the type properties.  Start the sweep command then modify your type adding a new type and selecting your profile.... That is if you set the profile use to the correct category when you created the profile.
Wed, Aug 27, 2008 at 9:08:22 AM | Category appears to be the problem.
Hogmodo
Hogmodo Avatar
3.5 Stars: 6 Votes
I have taken the one and only fascia sweep that comes up when I try to have my roof host a sweep, saved it as a new name, modified it, saved again, and loaded it into the project and it is not available when I try to have my roof host a sweep.  Then I go to the family editor, to the hosted profile, create the sweep, add it and same thing.  There is obviously something about designating the profile or family as something roof related that I am ignorant of.  Can you 'splain it to me, Lucy' as Desi would say?
Wed, Aug 27, 2008 at 9:35:36 AM | Help! Can't seem to find how to add new roof sweep profile.
In the family editor - look under settings/categories and parameters then pull down the profile usage and pick the correct category.
Wed, Aug 27, 2008 at 10:06:31 AM | Since no good dead goes unpunished.......................
Hogmodo
Hogmodo Avatar
3.5 Stars: 6 Votes
.....................you got me this far and now I have another problem.  I keep getting a "could not create fascia" error message when I try to use this profile (which is now available when hosting roof sweep) as an attached sweep.  This is a 2x6 vertical fascia board that I am attempting to attache "under" the edge of the roof.  Am I in one of those "you can't get there from here" moments?
Wed, Aug 27, 2008 at 11:04:40 AM | Help! Can't seem to find how to add new roof sweep profile.
The insertion point is the edge of the roof.  If you want the sweep located somewhere else, move it in the family.  It does not have to be at the insertion point.
Wed, Aug 27, 2008 at 11:14:00 AM | Help! Can't seem to find how to add new roof sweep profile.
4 Stars: 203 Votes
Did you try to delete those "CROSS LINES" inside the profile?????
Wed, Aug 27, 2008 at 11:57:43 AM | That did it!
Hogmodo
Hogmodo Avatar
3.5 Stars: 6 Votes
The stupid crossed lines was messing up my sweep.  Thank you!!!!!!!!!!!!!!1
Wed, Aug 27, 2008 at 12:45:04 PM | Help! Can't seem to find how to add new roof sweep profile.
4 Stars: 203 Votes
You Welcome...
Profile Sweep over Roof Cricket [ 1 2 ]
Fri, Sep 7, 2012 at 12:47:32 PM
27
how to add cornice to the roof ?
Tue, Aug 22, 2017 at 3:18:00 AM
Can't find Wall Sweep Profile.rvt in my family templates.
Thu, Dec 20, 2007 at 8:33:37 AM
Roof Edge Profile
Sat, Aug 26, 2006 at 11:08:28 AM
Sweep problem
Wed, May 21, 2014 at 9:21:17 AM
Page generation time: 1.9015
