74 Users Online (73 Members):
Forums >> Revit Building >> Technical Support >> Interior Elevation Crop Lines Height
36 Posts No Rating |
Revit Architecture 2009 Maybe i'm just missing it, but isn't there a way to set the height of interior elevations globally? I have 40 or 50 interior elevation views, and they all are from floor to ceiling (8'-0" AFF). Why do I have to go thru one by one and drag the bottom and top just perfectly so the floor and ceiling lines can be dimensioned to. I can't associate with a datum, because there is only one choice - "None". The size of the viewport is in paper space inches (not actual height). The top crop lines do not snap to the ceiling sometimes, and when they do, the ceiling line can't be dimensioned to.
Autodesk Revit MEP 2015 |
When you click on the camera to take the 3d view picture, there is an option at the top of the screen to set the dimensions of the picture that you are taking.
Belinski - You missed the question. jamiew - We struggle with this sometimes too. Our solution has been to make the view slightly larger than the interior so that we can dimension to model elements becaue we sure don't want to dimension to the view window! We then always print with the "Hide crop boundaries" checked.
Ya your right, sorry about that
Crop Region Size - Interior Elevation |
Thu, Oct 18, 2007 at 9:50:29 AM
Revit 2013- Adjusting the default setting for Interior Elevation crop boundary? |
Mon, Aug 26, 2013 at 4:23:48 PM
Backwards Crop Box on Interior Elevation |
Mon, Sep 24, 2012 at 2:02:32 PM
Interior Elevation Crop boundries |
Thu, Aug 13, 2009 at 12:13:24 PM
Interior Elevation Bold Outline - Revit 2009 |
Tue, Mar 14, 2017 at 2:56:00 PM
Members: | 2057441 | Objects: | 23074 | Forum Posts: | 152250 | Job Listings: | 3 |
