29 Users Online (27 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> How do I delete a named work plane that is no longer needed?
Mon, Aug 25, 2008 at 8:49:52 AM | How do I delete a named work plane that is no longer needed?
PWARREN
I am new to Revit. I understand work planes (creating, naming, visibility...) but HOW do i delete a workplane that i have created when i no longer need it? Is it me or is this less than straightforward? Thanks in advance to anyone who can help.
Mon, Aug 25, 2008 at 9:44:04 AM | How do I delete a named work plane that is no longer needed?
You do mean work plane - not reference plane?
Work planes are not really created - they are set.  As such, you never delete them, you just change which one is current.  When you open a floor plan, the work plane is automatically set to the level.   If you are in an elevation, you don't need a work plane unless you are creating a 3d element that needs a plane rather than a host.  3D lines in elevation is an example of something that needs a work plane.  But 2d lines require nothing.
Does this help your understanding?
Mon, Aug 25, 2008 at 9:55:06 AM | How do I delete a named work plane that is no longer needed?
PWARREN
Thanks. Created or set...Revit appears to be keeping a record of all the work planes i have used.
let me elaborate a bit. i have created work planes for creating 3D geometry of "in-place families," etc and it seems REVIT has even created and named some other work planes after I have picked faces of 3D elements in my model(see attached jpeg - e.g. "purlin 6", "purlin 23", etc). Now these work planes appear in my ever growing list and i dont need or want them anymore....
 so how do i tell REVIT to delete them so that my list contains only the ones i want and am likely to use again?
Mon, Aug 25, 2008 at 9:57:57 AM | How do I delete a named work plane that is no longer needed?
4 Stars: 203 Votes
PURGE
Mon, Aug 25, 2008 at 10:26:16 AM | How do I delete a named work plane that is no longer needed?
dano3d
3.5 Stars: 3 Votes
I don't think you could ever purge a "reference plane"? The only way I've ever been able to get rid of them in your pull-down list of work-planes is to FIND the reference plane, pick it, then delete. It will automatically disappear from the list after this procedure.  I've had problems when a reference plane was created at a weird angle on a section that was eventually deleted. With the section gone I could no longer find the reference plane to delete it.  It drove me crazy!!!
Mon, Aug 25, 2008 at 10:35:02 AM | How do I delete a named work plane that is no longer needed?
JRMello
Purge Unused will not get rid of Reference Planes, and after experimenting I found it will not remove unused Work Planes from the drop down list either. The only way I found was to delete the element that defines the work plane. Seems like a bit of a flaw.
Mon, Aug 25, 2008 at 10:35:39 AM | How do I delete a named work plane that is no longer needed?
4 Stars: 203 Votes
If you delete the ref. plane with that name when you Purge revit "Clean" the drawing...
Mon, Aug 25, 2008 at 10:45:11 AM | How do I delete a named work plane that is no longer needed?
PWARREN
Thanks. Agreed - this is cumbersome. You have to remember which view you created the reference plane in...and then delete them like they are objects. maybe its best to encode more information in the new refernce plane names give that we assign like "temp" and the name of the view in whiich they are hosted in e.g. ref plane name:  "temp-east elev-name"
 what a drag. surely somebody has a silver bullet.
Mon, Aug 25, 2008 at 10:50:11 AM | How do I delete a named work plane that is no longer needed?
dano3d
3.5 Stars: 3 Votes
It really does seem flawed.  A "purge" would certainly be a nice feature to have, but I'm sure the Revit Creators had a good reason not to give it to us.  You run the risk of purging a reference plane that has something important attached to it.
Mon, Aug 25, 2008 at 10:52:09 AM | How do I delete a named work plane that is no longer needed?
4 Stars: 203 Votes
But the biggest problem, i think is, when in your drawing you create several "Create-in-place" objects and inside them you create a lots of ref. planes with names, and sometimes there are inside the Voids...
Mon, Aug 25, 2008 at 10:57:44 AM | How do I delete a named work plane that is no longer needed?
dano3d
3.5 Stars: 3 Votes
your right Typhoon.  Naming reference planes inside an in-place family seems dangerous.  I never do it !!!
Mon, Aug 25, 2008 at 10:58:03 AM | How do I delete a named work plane that is no longer needed?
4 Stars: 203 Votes
But DANO3D, "You run the risk of purging a reference plane that has something important attached to it." when you do a Purge Revit ONLY purge what is in the Draw.. and it's NOT USING, so the problem is if you Delete a ref. plane with obj. attached and you aren't "Looking" and the obj. are gone.... but this is a issue you must pay atention and you know that's happen...
Mon, Aug 25, 2008 at 11:03:02 AM | How do I delete a named work plane that is no longer needed?
#13
dano3d
3.5 Stars: 3 Votes
Typhoon. You need to do a littlee experiment in Revit, because you really don't know what you're talking about.  Like everyone has been saying in this post... YOU CAN'T PURGE REFERENCE PLANES. TRY IT!!!!!!!!!!!
Thu, Jun 13, 2024 at 2:45:33 PM | How do I delete a named work plane that is no longer needed?
#14
orcinoronel
my work around here is create new reference plane. Then select that plane, right click then select all instances on entire project then hit delete..
Disassociating work plane
Thu, Apr 21, 2016 at 11:10:29 AM
Set roof or soffit on work plane?
Mon, Dec 2, 2013 at 12:57:50 PM
14
Model Line Between 2 different reference planes
Fri, Aug 2, 2013 at 2:56:20 PM
Work Plane Error
Thu, Nov 5, 2009 at 8:41:14 AM
get rid of current work plane and 3D snapping
Fri, Nov 10, 2006 at 3:26:53 AM
Page generation time: 2.0330
