44 Users Online (43 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Room Phases
Sat, Aug 23, 2008 at 7:45:03 AM | Room Phases
SteveB
3.5 Stars: 5 Votes
having already drawn walls, doors, windows and rooms with room tags, can you change all of that to a different phase?  It seems you can't change the room's properties to a different phase.  That means you would have to delete all the rooms and start over with all labeling, finish selections and other data.  Sad   (revit 2009).
Mon, Aug 25, 2008 at 2:04:13 AM | Room Phases
psymon
psymon Avatar
3.5 Stars: 6 Votes
You can cut and paste them into a view with a different phase setting.
If they are in proposed ground floor plan, pick the rooms and cut (or copy) them to the clipboard, then go to the existing ground floor plan and paste them.
HTH
Mon, Aug 25, 2008 at 6:55:29 AM | Room Phases
SteveB
3.5 Stars: 5 Votes
do you cut and past the rooms, the room tags or both?
Mon, Aug 25, 2008 at 6:53:37 PM | Room Phases
psymon
psymon Avatar
3.5 Stars: 6 Votes
You definately need to cut and paste the rooms as they are phase aware. The tags just show the properties of the rooms, so you can copy them as well or retag the rooms if you like,
I suggest you make a quick dummy example and experiment so you get a handle on it before you do a whole project!
Room tags and Phases
Thu, Jan 5, 2012 at 9:05:40 AM
Room Numbering & Phases
Thu, Aug 27, 2015 at 3:01:50 AM
Vanishing room tags
Tue, Sep 6, 2005 at 5:54:22 PM
Specific Looking Holes in Sectional Room Boundary
Fri, Oct 12, 2018 at 3:45:40 PM
Capabilities to isolate phases
Tue, Nov 28, 2006 at 5:43:03 AM
Page generation time: 0.5996
