37 Users Online (36 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Community >> The Studio >> Revit to 3d Max FBX
Fri, Aug 22, 2008 at 1:34:05 PM | Revit to 3d Max FBX
A1Gaudi
5 Stars: 5 Votes
Does anyone know how to import the FBX file to 3d Max.9? When I exported the files from Revit as 3d Max (FBX) and imported to 3d Max, the polylines all messed up and there were no materials mappings. I've also tried to export from revit to DWG and then to Max, but the material mappings did not export either. The model in Max appeared all yellow and pink.
Is there a way to export Revit model with all the materials maps into 3d Max?
Thanx.
Fri, Aug 22, 2008 at 2:14:23 PM | Revit to 3d Max FBX
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
I didn't know you could import a revit FBX into Max 9.... I use Max Design 09 and once I have exported my FBX it creates a material map folder thats pathed to the import, materials come in just fine.
Fri, Aug 22, 2008 at 2:48:40 PM | Revit to 3d Max FBX
4 Stars: 202 Votes
Alabaster, i did too once an export to FBX (Max Design 09) but not ALL materials show up fine, there are someone i just assign again and change too...
Mon, Aug 25, 2008 at 4:41:46 PM | Revit to 3d Max FBX
alabaster2513
3.5 Stars: 25 Votes
I have had a few instances where the scale of my materials do come into max incorrectly, the promaterials are a nice function if you are a basic user. I feel it easier to just set my materials by component the export to FBX then in max modify my materials with MR Arch Design materials to improve the overall quality of my renders.
Mon, Aug 25, 2008 at 10:05:08 PM | Revit to 3d Max FBX
A1Gaudi
5 Stars: 5 Votes
Thanks for the tip
Tue, Aug 26, 2008 at 7:56:03 AM | Revit to 3d Max FBX
Argyll
FBX from Revit to 3ds max only really works with 3ds max 2009 and I think your chances with R9 are about as good as mine are of becoming Pope. Your 'best' option with R9 is probably one of the DWG formats but you're up for a retexturing job. I found that I get an invalid file error when I try taking a Revit 2009 fbx file into 3ds 2008, but that's another story.
Tue, Aug 26, 2008 at 9:48:05 AM | Revit to 3d Max FBX
A1Gaudi
5 Stars: 5 Votes
It seems that 3ds Max doesn't recognize the FBX file (even though I have installed the plug in from the Max web). I guess the only option would be to reaply the materials after importing DWG into Max. I just thought to save the company some time...
Tue, Aug 26, 2008 at 9:58:32 AM | Revit to 3d Max FBX
4 Stars: 202 Votes
Hi, i have a friend, in this site is "RONIN LUSO" (search in Member list) and he work in revit since version 5, so if you see his Gallery all the renders are in MAX, he don't use revit to render because he spend lot a time to do it in revit and he tell me he NEVER PUT THE MATERIALS IN REVIT, he put the materials in MAX because the VRAY.
Tue, Aug 26, 2008 at 11:13:02 AM | Revit to 3d Max FBX
alabaster2513
3.5 Stars: 25 Votes
I am pretty sure I read somewhere that Revit doesn't support that FBX plugin, it only works with Max 09... I will see if i can find that thread on AUGI again.
The FBX vs DWG arguement can go back and forth forever, I see the DWG as a great to since it can be autmatically updated. My problem is that the DWG export doesn't always translate my geometry nicely from Revit. The FBX export handles complex shapes much better and it honestly does not take much to to replace modified elements.
Right now we use the FBX and our high end graphics guy imports it and replaces all the materials with Vray, it takes a little longer than my way but his renders produce faster and higher quality.
Tue, Aug 26, 2008 at 11:15:59 AM | Revit to 3d Max FBX
4 Stars: 202 Votes
That's why he don't put any material in revit, "it's a waste of time (double time)" put in revit and after again in MAX with VRAY mat.
Tue, Aug 26, 2008 at 12:10:05 PM | Revit to 3d Max FBX
alabaster2513
3.5 Stars: 25 Votes
I think it still helps to assign a material in Revit, I would not go as far as to render it or apply a map or anything. I like to think of it as the "Paint By Numbers" approach...
Fri, Dec 12, 2008 at 10:13:55 AM | Revit to 3d Max FBX
homebrew
homebrew Avatar
so even with the new improved rendering in revit 2009 it's still better to render in 3ds max for still pictures?
Fri, Dec 12, 2008 at 10:36:57 AM | Revit to 3d Max FBX
#13
katsmarios
3.5 Stars: 3 Votes
I have the same question as homebrew. Is it still not worth the effort to use the new mental ray renderer of revit 2009? Despite of the longer rendering time.....what about the quality result for still pictures?
Fri, Dec 12, 2008 at 11:05:06 AM | Revit to 3d Max FBX
#14
4 Stars: 202 Votes
Well, if you check my gallery you will see all images (Renders) are made in Revit...
Sun, Dec 14, 2008 at 10:49:25 AM | Revit to 3d Max FBX
#15
erland73
erland73 Avatar
4.5 Stars: 85 Votes
I think that it just depends on the quality you want for your images. If you want ultra realistic renders (but if you use it well, 'cause i've seen some renders made in Max that I scare), go with Max, but for me, i'm pretty satisfied with the results Revit's mental ray gives (see my images in the gallery, too.They're all rendered in Revit 2009).
Revit FBX causes 3DS Max to crash
Wed, Aug 10, 2016 at 6:02:28 PM
Revit 2009 to FBX Import into MAX 9?
Wed, Jan 21, 2009 at 1:12:23 PM
Exporting FBX file from Revit to 3Ds Max
Wed, Sep 30, 2020 at 1:36:50 PM
Revit 10 Model to FBX to 3Ds Studio Max Design lighting problem
Sat, May 1, 2010 at 12:55:26 PM
Revit FBX to 3D Max 2011 causes black or unresponsive viewports
Fri, Jan 13, 2012 at 11:29:52 AM
Page generation time: 1.4651
