149 Users Online (147 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Dimensioning to edge of railings
Fri, Aug 22, 2008 at 12:50:29 PM | Dimensioning to edge of railings
daleyy
I am doing several stairs in a project and am trying to dimension from tread to top of railing or from wall to edge of railing and I cannot get the edge to dimension.  I can tab to the center of the railing but not the edge.  Seem kind of odd that it does not let me do that since the industry needs this information.
I tried to snap another line to the the railing edge and dimension to the line but the line would not snap to the railing edge.
What am I missing here?
Thanks
DaleW
Fri, Aug 22, 2008 at 1:02:56 PM | Dimensioning to edge of railings
LIZARD2806
3.5 Stars: 7 Votes
I tried this with the "out of the box" stair and was able to measure the following:
1.  wall to side edge of rail
2.  wall at 90 degrees to stair run to front edge of railing
3.  wall at 90 degrees to stair run to front edge of tread
If you can't, it might be due to the railing you are using.
As for measuring the distance from tread to railing, obviously this dimension varies depending on where you measure from on the tread.  To do this, draw a Reference Plane on the top of the rail and then another Reference Plane vertically from the top of the tread (I assume you want the nosing edge).  Now you can draw a linear dimension, choosing the top of the tread first, then the intersection of the reference planes second.
HTH
**Using Revit Architecture 2009, 2011, and 2012**
Fri, Aug 22, 2008 at 2:51:00 PM | Dimensioning to edge of railings
4 Stars: 203 Votes
DALEYY, you don't tell what version of Revit are you working?
Dimensioning railings
Fri, Jul 24, 2009 at 3:04:00 PM
Detailing/dimensioning stairs and railings
Fri, Mar 16, 2007 at 2:14:13 PM
RAILINGS RAILINGS?????
Wed, Oct 1, 2008 at 3:48:49 PM
Frenc h railings
Wed, Feb 18, 2009 at 2:51:56 PM
11
Dimensioning to the centerpoint of an arc
Tue, Jul 29, 2008 at 4:11:55 PM
Page generation time: 0.3194
