44 Users Online (41 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Wall type missing Phasing parameter
Fri, Aug 22, 2008 at 10:45:12 AM | Wall type missing Phasing parameter
cholden
cholden Avatar
Revit 2009
I am currently working on a renovation project (our first endeavor with Revit phasing) and have been fine so far with existing phasing, new construction and demo. I missed a few walls and accidentally built them as new instead of existing. I tried to change a generic 8" wall type from new to existing but it does not have a phase parameter. I scrolled to the bottom of the element properties and its just not there. I am not sure why it doesn't have this instance parameter as all the other walls in the project do and are working fine. I feel like I'm missing something simple. Anyone have any suggestions as to where this phasing option went?
thx.
Fri, Aug 22, 2008 at 2:13:15 PM | Wall type missing Phasing parameter
LIZARD2806
3.5 Stars: 7 Votes
Silly question, but is there a "Phasing" section, just with nothing below it?  And if there is one, are the two carrots on the left of that bar pointing up?  If they are pointing down, click them and it will expand the category.  That's the "simple" solution.
**Using Revit Architecture 2009, 2011, and 2012**
Fri, Aug 22, 2008 at 2:26:08 PM | Wall type missing Phasing parameter
cholden
cholden Avatar
There isn't a Phasing section period. It is completely missing from the instance parameters section just on this one wall type. It's totally baffled me!
Wall Thickness in Type Parameter
Fri, Jun 1, 2018 at 7:39:16 AM
Phasing vs materials...Who is the boss when it comes to graphic overrides?
Mon, Nov 12, 2012 at 9:07:56 AM
Changing wall/wall tag parameter
Thu, Oct 14, 2010 at 12:44:43 PM
Using Filters for Phasing
Thu, Jul 27, 2017 at 7:44:15 AM
Wall and Instance phasing warning - Incorrectly Reporting?
Thu, Oct 11, 2018 at 3:37:01 PM
Page generation time: 1.5887
