95 Users Online (94 Members):
Forums >> Revit Structure >> Technical Support >> Text Leaders
10 Posts No Rating |
I find it hard to believe that I can't grab the end of a leader and "snap" it to and object, say either a beam or grid line. Am i missing something or do I really have to eyeball it? Thanks in advance.
It snaps sometimes, but all you have to do is put the blue dot as close as you can to the object and it will look perfect. The only way you can tell thats its not perfect is if you zoom way in. HTH
Text doesnt snap because it doesnt see anything as being its host. If you want the leader to snap you would have to use a label or keynote. Then it sticks to the object unless you use a "free end" in which case Revit assumes you want it truely free and does not snap... HTH Nick
Cannot turn on leaders for text boxes inside custom annotation. |
Wed, Aug 13, 2008 at 9:10:58 AM
Leaders contrained to angles without text |
Thu, Jan 11, 2007 at 5:15:00 PM
Problem with text leaders when using crop regions |
Fri, May 6, 2011 at 8:24:33 AM
Leaders moving_Annoying |
Fri, Jan 20, 2012 at 7:37:30 AM
Multiple leaders in Keynote Tag ?? |
Fri, Jun 28, 2013 at 8:46:43 AM
Members: | 2070322 | Objects: | 23097 | Forum Posts: | 152265 | Job Listings: | 3 |
