67 Users Online (65 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Community >> The Studio >> convert CAD file to PAT file for surface patterns in Revit
Thu, Aug 21, 2008 at 10:18:18 AM | convert CAD file to PAT file for surface patterns in Revit
tinninttu
how would you go about creating a surface pattern in Cad and then converting it to a .pat file to be used as a surface pattern in revit for an exterior wall surface?
Thank you Smile
Thu, Aug 21, 2008 at 3:13:00 PM | convert CAD file to PAT file for surface patterns in Revit
NKramer
4 Stars: 9 Votes
Create in cad, copy to HatchKit, create hatch .pat file, import .pat file to Revit.
HatchKit costs about $100 but is worth it if you have a decent sized firm and dont want to learn the text formating of patterns.
 http://www.cadro.com.au/hatchkit/
HTH
Nick
Mon, Aug 25, 2008 at 8:15:41 AM | convert CAD file to PAT file for surface patterns in Revit
cadpro78
cadpro78 Avatar
3 Stars: 2 Votes
Okay I have the demo for Hatchkit and I am trying to create a hatch. I have created the pattern I want in ACAD, then I tried to copy the pattern to Hatchkit, but it doesn't get copied in? What do you mean by copy? Like Copy and Paste???
Tim McDougald
CHILDREY ROBINSON ASSOCIATES
1212 Kenilworth Avenue
Charlotte, NC  28204
Mon, Aug 25, 2008 at 1:37:57 PM | convert CAD file to PAT file for surface patterns in Revit
NKramer
4 Stars: 9 Votes
You have to use the Windows Clipboard option from the file menu to get the pattern into hatch kit. Then you have to define the extents of the repeating portions with the red and blue lines. After that you just need to export the file as a .pat.
Let me know if that works for you.
Nick
Mon, Aug 25, 2008 at 1:50:30 PM | convert CAD file to PAT file for surface patterns in Revit
JRMello
If you have an AutoCAD .pat file that you want to use in Revit, just open it in Notepad and add the line:
;%TYPE=MODEL
or
;%TYPE=DRAFTING
on the second line. Save the file, and you should be able to import it into Revit.
create/ convert hatch patterns (.pat) to revit fill patterns
Tue, Jun 2, 2015 at 11:29:00 AM
Import PAT File
Tue, Dec 14, 2010 at 9:42:43 AM
Revit 2012, cannot import custom pattern from .pat file
Wed, Dec 30, 2015 at 8:31:18 PM
Is there a way to preview .pat files / hatch patterns in thumbnails in a folder?
Mon, Jul 6, 2015 at 11:01:26 AM
How to scale Hatch Patterns already loaded in file?
Tue, Apr 19, 2011 at 3:11:31 PM
Page generation time: 3.6236
