66 Users Online (64 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Changing Sheet References
Wed, Aug 20, 2008 at 5:13:07 PM | Changing Sheet References
BrettoH75
Hi, is it possible to chang the referencing sheet for sections and details. The reason for this is i cut a section while in the floor plan but once i placed the section view on a sheet it wonts to refernece to view back to the elevation sheet which is not what i wont. I wont the section to reference the floor plan sheet. Any ideas
Brett
Wed, Aug 20, 2008 at 5:18:31 PM | Changing Sheet References
BrettoH75
Ok on further investigation the reference is based on sheet order - but is there a workaround for this other than putting text over the offending reference or creating an editable tag?
Brett
Thu, Aug 21, 2008 at 6:45:04 AM | Changing Sheet References
I believe what you are asking to do is the old "shown on" / "called out on" annotating. We used this in the past and it's nice but I haven't seen it used in REVIT. I have not tried to set this up - why don't you see if you can. REVIT does keep track of this information.
Good news.  I just checked it out and you can select the referencing sheet parameter when you edit the title family.
Edited on: Thu, Aug 21, 2008 at 6:48:45 AM
Thu, Sep 18, 2008 at 12:23:07 AM | Changing Sheet References
BrettoH75
do you mean in the family is self or from edit while in the project - i have looked at both and done see where i am able to change it to reference another view. All options are greyed out in the family after editing label and if editing the view title in the project it shows the sheet thats being referenced but its greyed out aswell and unable to be change?
i must not be understanding what you mean sorry.
Brett
Thu, Sep 18, 2008 at 7:51:45 AM | Changing Sheet References
In the call-out family - see attached screen shot
Thu, Sep 18, 2008 at 9:57:07 PM | Changing Sheet References
BrettoH75
ok i thought that was it, all i have done for now is added another bit of text for the 3 dashes i use (---) and added visability parameters for it and made a new type for detail this sheet.
thanks for the help
Brett
View References in Text and Keynotes
Fri, May 22, 2015 at 1:05:21 PM
View References issue in 2013
Thu, Aug 8, 2013 at 1:10:19 PM
INDEX OF DETAIL REFERENCES
Tue, Apr 8, 2014 at 11:41:27 AM
View References... how do they work?
Wed, Feb 27, 2008 at 3:00:43 PM
View Reference tags in parent view disappear when viewing the parent sheet
Fri, Nov 6, 2009 at 3:32:27 PM
Page generation time: 0.7001
