64 Users Online (61 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> pattern on stairs
Wed, Aug 20, 2008 at 8:38:46 AM | pattern on stairs
eveline
I assigned a material with a floor tile pattern to the treads of a stair.The floor tile pattern does not show on the stairs in plan view. It is visable in 3d. How can I let it show in plan view?.
Wed, Aug 20, 2008 at 9:26:17 AM | pattern on stairs
4 Stars: 201 Votes
Hi, in plan view you are in coarse, medium or high view mode? do you "play" with this and check if appears? do you ZOOm IN to stairs and check if you can See? Can you post some screen shots with this? in the menu properties of the materials, and a view in plan and 3d?
Wed, Aug 20, 2008 at 9:56:45 AM | pattern on stairs
eveline
Detail level is fine. Tiles do show on the floor. That is the same tile. Other patterns don't show either. Colour does.
Thank you for answering.
Wed, Aug 20, 2008 at 10:15:07 AM | pattern on stairs
Belinski
4 Stars: 5 Votes
Like typhoon said, did you mess with the course, medium and fine setting in plan view?
Wed, Aug 20, 2008 at 10:32:16 AM | pattern on stairs
4 Stars: 201 Votes
Hi EVELINE, in that "Plan View" VG, then go to down to "STAIRS" and in  the "Projection/Surfaces" in "Patterns" pick in the field "Overrides", it open a new box when you can check if "Visible" are "on" if not check it then select a "Color" and select the "Pattern"....
Thu, Aug 21, 2008 at 1:47:00 AM | pattern on stairs
eveline
There are no overrides as far as I can see.
Thu, Aug 21, 2008 at 4:10:14 AM | pattern on stairs
4 Stars: 201 Votes
Well, in your image it's CLEAR (CRISTAL...), on the right of the "Stairs" you have 4 (four) fields with "Override...", don't you see? look the image you post.... then follow what i post before....
Thu, Aug 21, 2008 at 4:53:56 AM | pattern on stairs
eveline
I do see it, I just don't get it. Sorry.
Doesn't the box "fill patterns" say that no overrides are active?
Thu, Aug 21, 2008 at 5:07:16 AM | pattern on stairs
4 Stars: 201 Votes
Yeah EVELINE, that's the point, in your picture you have that new box where are ON the "VISIBLE" and you have in the color and the pattern "<NO OVERRIDE>", so you must click in the "No Override in COLOR" and change that color, even if you want the same color actually you must select the color, then in "No Override PATTERN" you MUST select the pattern you want, then when you pick OK, apply, Ok, you can see in the PLAN VIEW the changes you just made.....
If you need more information tell something...
Thu, Aug 21, 2008 at 5:27:12 AM | pattern on stairs
eveline
Would'nt that affect all the stairs? This are the only stairs in tiles.
Thu, Aug 21, 2008 at 5:35:03 AM | pattern on stairs
4 Stars: 201 Votes
Yes, this affect all the stairs in this PLAN VIEW....
Thu, Aug 21, 2008 at 5:41:05 AM | pattern on stairs
eveline
Thas is not a solution than.
I think it is strange that, altough the material of the treads is tiles it does not show.
Thank you for thinking with me though.
Thu, Aug 21, 2008 at 6:26:28 AM | pattern on stairs
#13
4 Stars: 201 Votes
EVELINE, if in this case "This are the only stairs in tiles" well, go to drafting menu and create a "Filled Region" with invisible lines around the stair (lock them to stair) and with that pattern, and put the background "Transparent".... because really i don't have here the RAC 2009, and i don't understand why when we change the pattern to the stairs "in drafting" and "in Modelling" and "he" don't assume that....
Everyone?
Thu, Aug 21, 2008 at 6:49:05 AM | pattern on stairs
#14
eveline
Yes, that will have to be the practical solution. I hope to find a more strucutal one one day.
Sun, Aug 24, 2008 at 2:46:57 PM | pattern on stairs
#15
4 Stars: 201 Votes
Hi EVELINE, see the video: http://screencast.com/t/jxtsj4Dkn7
Surface pattern on stairs
Mon, Mar 29, 2010 at 6:47:25 AM
Stiar cut pattern or fill pattern.
Sun, Feb 19, 2006 at 11:46:36 PM
Unable to rotate/align surface pattern on stairs
Thu, Aug 28, 2014 at 7:29:20 AM
non typical stairs
Wed, Jul 16, 2008 at 1:03:16 PM
Stair Surface Pattern Not Displaying
Wed, Sep 8, 2010 at 10:05:09 AM
Page generation time: 0.4663
