Forums >> Revit Building >> Technical Support >> adding details...
10 Posts No Rating |
I have a sheet with two floor plans and two window details. The plans are using a title bar created for plans and the window details are using a title bar for our window details. The problem is that the numbering scheme won't allow me to have a plan detail numbered 1 and a window detail numbered 1 as well. Am I missing something? Is there a work around on this? Any help will be greatly appreciated. Mike
OOps I am using Revit 2008 Build 20071109_2345
Hi, can you put some screen shot of this?
![JAMESHGRIMES Avatar](user_avatar/17328.jpg)
![4.5 Stars: 10 Votes](/images/stars_4.5.gif) |
It is not possible for Revit to allow two #1 details on the same sheet. This is due to the fact that Revit is coordinating the views across the whole project and it would know which one to connect to. My suggestion is to make a generic symbol to depict the number if you absolutley need it to be #1.
James, I am curious though how can you have multiple sets of sheets and then have consecutive numbers through out the project? I haven't ever seen that before. It would seem that if you have viewports from different aspects ie plans, sections, elevations and drafting details you should be able to label them differently especially if using a different viewport title...
Here is a screen shot of the two types of viewport titles I am using. I hope it comes through alright.
![4 Stars: 5 Votes](/images/stars_4.gif) |
Nope, james is right you cant label something the same on a given sheet because then it wouldnt be 'smart' you need to use sub-intervals like a or b or just number them differently
Thanks for all the input...It sounds like the approach to the numbering convention will have to be using a unique classification for details.
Adding extra details- elevations |
Tue, Feb 5, 2008 at 2:15:23 PM
Snapping to Details Lines? |
Thu, Nov 19, 2009 at 12:18:58 PM
query with elevation details |
Mon, Dec 1, 2008 at 5:12:35 AM
Shared Details |
Wed, Sep 17, 2008 at 10:35:49 AM
Typical Details |
Thu, Aug 28, 2014 at 7:54:38 AM
