19 Users Online (18 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> hiding part of a usage tag
Mon, Aug 18, 2008 at 6:40:45 PM | hiding part of a usage tag
archi3
using a usage tag that has the room name, SF, and uage. I want to hide the usage line, so that although the area sorts by that attribute in the schedule it is not seen on the plan? I was able to do hide in another tag since there was a box in the element properties that I was able to uncheck and hide the usage type, but this other tage type does not have that box in the element properties. where I do make this not visible?
Mon, Aug 18, 2008 at 6:50:23 PM | hiding part of a usage tag
Belinski
4 Stars: 5 Votes
Hi,
edit the family and add a yes/no parameter to make that visible or not.
let me know if you need to know how to make this parameter
Tue, Aug 19, 2008 at 10:28:11 AM | hiding part of a usage tag
archi3
thanks,
so how do you add a parameter?
Tue, Aug 19, 2008 at 10:34:19 AM | hiding part of a usage tag
As with most questions in REVIT, the best and first place to find your answers is the HELP file.  Look under parameters.  You don't need a shared parameter for this so look at "Creating new parameters" ...
Tue, Aug 19, 2008 at 10:38:12 AM | hiding part of a usage tag
Belinski
4 Stars: 5 Votes
You dont have any experience adding any type of parameters?
Tue, Aug 19, 2008 at 11:48:20 AM | hiding part of a usage tag
archi3
some experience mainly editing though, haven't created new ones. I found where to add a parameter but everything was grayed out and I wasn't able to.
Tue, Aug 19, 2008 at 12:55:16 PM | hiding part of a usage tag
4 Stars: 203 Votes
Hey, WWhub is right, you should go to F1 and try to learn and understand the "families creation" but i gonna put a video for you, wait a few minutes...
Tue, Aug 19, 2008 at 1:00:01 PM | hiding part of a usage tag
4 Stars: 203 Votes
Hey, this is the video: http://screencast.com/t/mwS57J4nTmw
Hiding a detail in all views in one step
Thu, Jan 21, 2010 at 2:04:15 PM
structural usage for stacked walls
Tue, Jun 30, 2015 at 6:59:57 PM
memory usage in Revit 7
Tue, Jun 21, 2005 at 6:04:56 PM
hiding scale on view title tag
Wed, Aug 1, 2018 at 1:17:43 PM
How to use Project Number as a part of TAG
Thu, Dec 14, 2023 at 6:05:58 AM
Page generation time: 2.3323
