35 Users Online (34 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> General Discussion >> Revit Project Management >> ERROR MESSAGE: STAIRS - rises not intersecting boundries?
Mon, Aug 18, 2008 at 3:34:23 PM | ERROR MESSAGE: STAIRS - rises not intersecting boundries?
cadpro78
cadpro78 Avatar
3 Stars: 2 Votes
ex4-6 Error Report (8/18/2008 4:15:32 PM)
Error message Elements The line representing the top of a riser does not intersect one or both of the boundary lines. : Model Lines : id 151963
This is the error message I keep getting when I try to make a U-flight of stairs in a bldg. Is anyone else getting this type of message?
Tim McDougald
CHILDREY ROBINSON ASSOCIATES
1212 Kenilworth Avenue
Charlotte, NC  28204
Mon, Aug 18, 2008 at 3:35:37 PM | ERROR MESSAGE: STAIRS - rises not intersecting boundries?
broncos4life
3.5 Stars: 11 Votes
Do a print capture of the sketch screne for your staris and post it. Please
Mon, Aug 18, 2008 at 4:01:00 PM | ERROR MESSAGE: STAIRS - rises not intersecting boundries?
4 Stars: 202 Votes
Yeah, put some screen shots from the stairs and the menu properties of that to figure out...
Tue, Aug 19, 2008 at 7:15:26 AM | ERROR MESSAGE: STAIRS - rises not intersecting boundries?
cadpro78
cadpro78 Avatar
3 Stars: 2 Votes
Ok here is the problem.  I have two attachments. One of the staircase as it is currently and the error message I get when I finish it?
Tim McDougald
Charlotte, NC  28204
Tue, Aug 19, 2008 at 7:50:42 AM | ERROR MESSAGE: STAIRS - rises not intersecting boundries?
broncos4life
3.5 Stars: 11 Votes
For this error be sure that all the boundry lines are trimed together to form 2 chains...the inner U and the outer U, and make sure you dont have any outlying boundry lines that may be too small to see.
Tue, Aug 19, 2008 at 8:51:12 AM | ERROR MESSAGE: STAIRS - rises not intersecting boundries?
4 Stars: 202 Votes
OR, you draw the same line twice (one line in the top of the other)
Edited on: Tue, Aug 19, 2008 at 2:21:27 PM
Tue, Aug 19, 2008 at 9:12:34 AM | ERROR MESSAGE: STAIRS - rises not intersecting boundries?
lunchtrayrider
3.5 Stars: 7 Votes
it looks like your sketching the runs with the boundary and riser lines.  its easier to make that stair using the create run tool.  should also prevent your error.
I like scooters. and motorcycles.
Error message creating stairs
Tue, Jul 13, 2010 at 7:27:12 PM
Stairs going in the wrong direction
Sun, Feb 15, 2009 at 5:41:36 PM
How to make T-Shaped Stairs
Thu, Mar 8, 2007 at 1:02:18 PM
Revit 2014 - Disappearing error message
Wed, Nov 6, 2013 at 4:12:49 PM
PLACING ROOMS WITH ERROR MESSAGE ABOUT ADJUSTING LIMITS 2016
Tue, Oct 4, 2016 at 9:09:34 AM
Page generation time: 0.3797
