112 Users Online (111 Members):
Forums >> Revit Structure >> Technical Support >> issues rendering
22 Posts No Rating |
Hi guys and girls A quick question regarding rendering and computer spec. My company have just bought me a new Dell Precision workstation T5400 with the following specCPU - Xeon E5405 2GHz Duo Quad core (8 cpus)RAM - 4GbHDD - 140GbGraphics - NVidia Quadro NVS 290 (256Mb) Now with this spec i'd have thought it wouldnt have had many problems with rendering but i get the message 'there is not enough memory to create the rendered image. close unnecessary project views and applications, and/or reduce the size of the rendered image by shrinking the crop region or reducing the image resolution'. If i drop the resolution i then egt a message saying theres not enough space on the hard drive which is daft as theres well over 120G still available. I wouldnt have said that the drawing im rendering is particularly complex, only columns, beams and slabs - the file is only 10Mb. Any ideas how to solve this? Thanks, Adam
Can u just paste a snapshot so we can get a better idea & also what version r u working in?
Chirag C. Pawar Cad Solution Application Senior Engineer KLGSystel Ltd. India 301, Pujit Plaza, Plot No. 67,Sector 11, CBD Belapur,Navi Mumbai - 400614, Maharashtra, India.Tel .: +91 22 409 16777. Extn. - 718Fax .: +91 22 275 76461.Mob .: +91 99 698 66851.Email.: chiragp@klgsystel.com Web .: www.klgsystel.com |
Am running Revit Structure 2009 whats the difference between rendering 'screen' and 'printer'? it renders when its on the 'screen' option
Hi, it's strange because with that caracteristics "he" should work VERY good, i have a Dual-Core 2.4Mhz, 3Gb Ram, ATI-512Mb and it works "Cristal", did you upgrade to the SP1 (Web update)?
What OS are you running? If you are running XP x86 do you have the 3 Gig switch turned? Even better you may look into updating to XP x64 which uses ram differently which improves how well Revit runs. Make sure you have the most up-to-date drive for your graphics card. One note is that Revit 2009's renderings will only use 4 cores max at the moment. Rendering print just fits it to a paper size. Typhoon you are using ATI which is AutoDesk recomended btw where NVidia isnt...not sure if this is the problem though.
I use also Windows Vista 64 bits...
Rendering Issues!!! |
Mon, Sep 29, 2014 at 8:52:19 AM
Rendering Plants |
Fri, Jul 15, 2016 at 2:32:08 PM
Issues with rendering some of my christmas lights |
Mon, Dec 2, 2013 at 12:16:45 PM
If you are having cloud rendering issues "Bug" |
Mon, May 20, 2013 at 3:40:19 PM
IMproving rendering of walkthroughs |
Wed, Jun 28, 2006 at 5:07:25 AM
Members: | 2088715 | Objects: | 23142 | Forum Posts: | 152276 | Job Listings: | 3 |
