62 Users Online (61 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Systems >> Technical Support >> Export a 3D veiw to pdf
Sun, Aug 17, 2008 at 7:35:44 PM | Export a 3D veiw to pdf
matto
2 Stars: 1 Votes
In Revit Architecture 06 you could export the 3D view to a pdf file so the client could orbit the model without downloading another programme. In Revit Architectur 09 this is not an option, is there a way to achieve this?
Sun, Aug 17, 2008 at 9:27:10 PM | Export a 3D veiw to pdf
coreed
coreed Avatar
4 Stars: 16 Votes
there was no Revit Architecture 06?
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Mon, Aug 18, 2008 at 3:36:08 AM | Export a 3D veiw to pdf
4 Stars: 202 Votes
I think he want to mean Revit Architectural 2008....
Mon, Aug 18, 2008 at 3:41:36 AM | Export a 3D veiw to pdf
chiragpklg
4 Stars: 11 Votes
Well coreed I also accept that there was no Revot 06, but still I wld like to know tht whether it is possible to export 3d view to pdf. in Revit 09
Chirag C. Pawar
Cad Solution Application Senior Engineer
KLGSystel Ltd. India
301, Pujit Plaza, Plot No. 67,Sector 11, CBD Belapur,Navi Mumbai - 400614, Maharashtra, India.Tel    .:    +91 22 409 16777. Extn. - 718Fax   .:    +91 22 275 76461.Mob  .:   +91 99 698 66851.Email.:    chiragp@klgsystel.com
Web  .:    www.klgsystel.com
Mon, Aug 18, 2008 at 5:26:54 AM | Export a 3D veiw to pdf
Dafpfy
3.5 Stars: 11 Votes
file/publish dwf/ 3d dwf
clients will have to dl a dwf viewer but i guess thats free.
with this they can make there own sections and allot more, ( just about everything to look at the building exept changing it)
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
Mon, Aug 18, 2008 at 7:41:24 AM | Export a 3D veiw to pdf
I think there is some confusion here between export and print .... dwf & pdf.
When I hear export, I think of creating a file that can be read and manipulated by a different program.  Printing is simply a 2d operation.  3D pdf's and 3D dwf's are kind of a cross between the two processes but they only contain limited information.  So my question is what do you want?  You can easily print a 2d pdf throught the print command.  You can also publish to a 2d or 3D dwf.    But you can't export to either one of these.
All of this information is available through your help menu.  And like most help menu's .... if it doesn't have a listing for it, it probably doesn't do it.
Wed, Aug 27, 2008 at 12:33:17 AM | Export a 3D veiw to pdf
matto
2 Stars: 1 Votes
Printing directly to a PDF file with Revit cannot be done. However, you can export sheets to a DWG file and then use DWG TrueView™ 2009 to open the DWG files and print them to PDF.When printing in DWG TrueView 2009, use the DWG to PDF.pc3 printer to create PDF files.The latest version of DWG TrueView can be downloaded from http://usa.autodesk.com/adsk/servlet/index?id=6703438&siteID=123112
Neither Revit Architecture 2008  nor Revit Architecture 2009 included any PDF driver applicationIf you already had Adobe Acrobat –or any other PDF writer- installed on your system, you should be able to use the same writer to create PDF files with Revit Architecture 2008
Wed, Aug 27, 2008 at 9:53:54 AM | Export a 3D veiw to pdf
matto - Sorry but you are mistaken.
We print directly to a pdf file using cute pdf. This is how we send all of our documents to our outside print company. The great think about REVIT making pdf's is that we can create one pdf having all the sheets.
You can't print to a 3d pdf but you can create a 3d dwf.
Edited on: Wed, Aug 27, 2008 at 9:55:24 AM
Thu, Oct 30, 2008 at 4:07:29 PM | Export a 3D veiw to pdf
hardisu
Everyone is getting confused about the original question, most likely because they have never seen it before. It is possible to create 3D .pdf files readable by Adobe Reader. You cannot create these natively in Revit but you can export to a 3D .dwf and then convert the .dwf to a 3D .pdf. It also compressed the file size considerably as most of the information is lost in the process. This is very helpful because most people dont have TrueView, but almost everyone has Adobe Reader installed.
Fri, Oct 31, 2008 at 9:15:45 AM | Export a 3D veiw to pdf
hardisu,
I know you can create a 3D pdf if you have the program to do so ... which most people do not and that is what the original poster did not want to do.  But as already posted - 3d dwf's are available directly out of REVIT and the viewer is free ... and besides that, the 3d dwf is so useful in other ways.
If you have not tried the 3d dwf viewer, I suggest you do.
Mon, Nov 3, 2008 at 5:07:22 PM | Export a 3D veiw to pdf
hardisu
@ WWHub
Good point. I forget that my firm has the Adobe 3D program at its disposal. We have found it extremely useful when trying to show subcontractors certain areas that they should look out for or give them a general feel for a project. Also file sizes are small and can easily be sent via email. I agree the dwf viewer is much better for those who know what they are doing in front of a computer screen.
Thu, Sep 1, 2011 at 11:00:45 PM | Export a 3D veiw to pdf
lukej2000
Here is the answer as of September 2011:
<a href="http://whatrevitwants.blogspot.com/2011/09/create-3d-pdf-files-from-autodesk-revit.html">What Revit Wants: Create 3D PDF files from Autodesk Revit for free</a>
Thu, Sep 1, 2011 at 11:01:46 PM | Export a 3D veiw to pdf
#13
lukej2000
Tue, Sep 13, 2011 at 9:10:54 PM | Export a 3D veiw to pdf
#14
lukej2000
And here is how to convert a 3D DWF to a 3D PDF http://whatrevitwants.blogspot.com/2...ctly-from.html
Export PDF
Wed, Nov 30, 2011 at 12:26:08 PM
Export Schedule into PDF format
Wed, Sep 2, 2009 at 12:08:19 PM
MAP TEXTURE IMAGES TO ELEVATIONS AND FLOOR PLANS
Mon, Mar 5, 2007 at 1:17:29 PM
Export PDF from Revit 2013 sheets
Sun, Mar 9, 2014 at 10:16:36 PM
after revit export to pdf the file is wrong scale
Sat, Nov 20, 2010 at 10:54:05 PM
Page generation time: 0.3240
