Forums >> Revit Building >> Technical Support >> Rendering in 2008-Why are some cars invisible and others not?
Vehicles and people that I have rendered successfully in the past are now not visible when placed in the project. Any ideas on how to fix this?
Are you really render in 2008 or 2009? because i have this issue when i open a project in 2009 done in 2008... can you put some screen shot in 3D view to can see?
I am not sure about the screen shot showing the empty parking lot where the vehicle is not appearing but I can attach two vehicle files. The explorer file shows up in the rendering and in the 3D image. The BMW does not. It used to work, but now it doesn't. What changed. I am rendering in 2008 because I want a background image in the rendering and 2009 won't allow that option. Another thing. How do you get the reflective bumpers, glass, etc. from showing the reflection of the blue default background that is behind the camera? I got one shiny bumper that has an ugly blue reflection on the upper surface of the bumper.
Hi, " I got one shiny bumper that has an ugly blue reflection on the upper surface of the bumper." to remove that in render.-settings go to environment and in"background Color" select "Solid Color" then put RGB all 255 (white), in this way the "ugly blue reflection" dissapears... i gonna check your models...
Ok, i see the problem, see the video: http://screencast.com/t/zvMnGsQwx Do you have the libraries (*.mlib) of Accustudio in the right place? do you delete some one of them? in Revit "Settings-options-file locations" do you have in Libraries- Librarie Name and Library path the name and the path to the correct drive and folder?
rendering cars |
Mon, Aug 13, 2007 at 1:23:34 PM
Cars with Rendering Lines |
Fri, Mar 23, 2012 at 12:01:11 AM
Rendering Cars |
Mon, Nov 28, 2005 at 3:33:28 PM
Rendering an invisible wall. |
Sun, Apr 24, 2011 at 12:01:50 PM
3d max people and cars to revit |
Wed, Dec 18, 2013 at 1:11:12 PM
Members: | 2100940 | Objects: | 23173 | Forum Posts: | 152292 | Job Listings: | 3 |
