Forums >> Community >> The Studio >> scale surface patterns
35 Posts No Rating |
how do you scale the surface patterns in the materials dialogue of a wall/ i searched the help menu, but found nothing. I have the surface pattern "slate" on an exterior wall but it is huge! there is a scale factor but it's grayed out. how am i able to modify it?
Hi, in that menu pick in "Custom" then "Import", select the pattern you want and Open, then change the "import Scale" value...
ok, i see that but is there a way to scale the patterns that are standard to revit, not imported? or do i find a folder where those standard patterns are being saved and import it from there? Thanks for your reply
I have a folder where i have and download all my patterns, so when i need i go there and import the pattern i want so i can change what i want...
How to scale Hatch Patterns already loaded in file? |
Tue, Apr 19, 2011 at 3:11:31 PM
Surface Patterns in Perspective |
Fri, Jan 27, 2012 at 7:04:34 AM
Surface Patterns |
Wed, Mar 4, 2009 at 11:24:15 AM
Existing Phase Surface Patterns visibility |
Tue, Nov 14, 2006 at 6:37:24 PM
materail surface patterns |
Fri, Jun 13, 2008 at 8:06:11 AM
Members: | 2115752 | Objects: | 23192 | Forum Posts: | 152301 | Job Listings: | 3 |
