Forums >> Revit Structure >> Technical Support >> Placing objects on ramps
22 Posts No Rating |
Its probably a simple issue to solve but how do i orientate an object to sit on a ramp, for example a car on a car park ramp?I've tried to align, move and/or rotate but with no luck.
It's simple, edit the family of the CAR for ex. then go top menu "Settings - Family Category and Parameters" then UNCHECK-Always Vertical, save and load to project, the car align to the object...
i knew it'd be a simple fix. Thanks a lot!!!
You welcome...
Placing objects in 2D, but cant see the in 3D. |
Fri, Jun 22, 2012 at 2:21:52 PM
Attach Walls to Ramps |
Fri, Feb 18, 2011 at 6:45:17 AM
Showing break lines with Ramps and Stairs |
Mon, Jul 30, 2018 at 11:02:37 AM
TYPE SELECTOR for ramps and stairs |
Thu, May 3, 2007 at 2:46:54 AM
Ramps, What are they good for? Absolutely nothing |
Tue, Dec 6, 2011 at 9:57:52 AM
Members: | 2102455 | Objects: | 23173 | Forum Posts: | 152296 | Job Listings: | 3 |
