65 Users Online (63 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Yes/No Parameter
Thu, Aug 14, 2008 at 3:26:49 PM | Yes/No Parameter
notagain
notagain Avatar
4 Stars: 1 Votes
could some explain how this works...I was under the impression that it could be toggled on/off and values where associated to this parameter...but doesn't seem to work that way...need a little help
I really want this to work...some good things some bad
Thu, Aug 14, 2008 at 3:32:08 PM | Yes/No Parameter
Belinski
4 Stars: 5 Votes
You can asign something the yes/no parameter if you want to have the choice of showing or not showing something that is apart of the given family.
when you go to the element properties of the certain thing that you want to have this control over, you select the box to the far right of where it says 'visibility'.
you will then see this box in the project when you go to the family's element properties and you can check or uncheck it as an instance or type (however you decide to make it)
Edited on: Thu, Aug 14, 2008 at 3:32:35 PM
Can a Yes/No Parameter control a Length Parameter?
Thu, Mar 22, 2012 at 12:17:27 AM
Referencing a Shared Parameter in a Family parameter formula.
Thu, Jan 29, 2015 at 1:26:24 PM
Add angle parameter to generic annotation with offset parameter
Mon, Mar 2, 2020 at 12:57:06 AM
Add Family name to a shared parameter
Tue, Jun 23, 2015 at 8:50:48 AM
NOT Parameter Formula Question
Fri, Apr 10, 2009 at 8:30:17 AM
Page generation time: 0.4826
