45 Users Online (43 Members):
Forums >> Revit Building >> Technical Support >> Window not rendering?
38 Posts No Rating |
Revit Architecture 09 I created a window from scratch just as I did most others, but for some reason it does not want to render. It is visible in all modes except when rendered. The settings seem to be the same for all windows. Is there a checkbox to make visible in rendering mode or another reason it does not want to render Thanks
![4 Stars: 5 Votes](/images/stars_4.gif) |
Did you make sure you appointed a render surface material to this window?
1 Posts No Rating |
Try making a phase filter (call it Completed) with every category as "By Category" except Demo, which should be "Not Displayed." In the 3d view that you want to render, select Completed for your phasing filter for that view. Hope this helps, I had the same problem and it worked for me.
lights not working in 3D or rendering |
Thu, Jul 11, 2013 at 10:56:36 AM
window frame wont show in rendering |
Tue, Dec 28, 2010 at 2:51:55 PM
RevitCity I have a problem! |
Tue, Aug 11, 2009 at 3:38:07 PM
INTERIOR RENDERING |
Mon, Jul 9, 2007 at 1:02:31 PM
Interior Window Trim |
Fri, Apr 20, 2012 at 12:04:29 PM
Members: | 2022396 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
