Forums >> Revit Systems >> Technical Support >> wrapping wall materials
5 Posts No Rating |
Please i need someone to help me with my wall wrapping. I created a 225mm wall that has 3 layers: Exterior finish, then i split the wall and added another layer which i assaigned to the lower part of the the wall so i could have a stone finish below and then concrete above. Now my problem comes when i created an opening in the wall and the opening was wrapped with the concrete even to the layer below, then i proceeded to turrn off wrapping for the concrete layer but now the stone layer wraps all the way to the top. Please can anyone help me with this
Hi, if i had to create this model i don't do it jut like you do, i just create that "Columns" with a material, then above them create a wall with different material and edit that wall and create those "arcs" (don't use openings) and after that i create using Moddeling - Solid Form - Solid Sweep that sweep around the columns with a 3 material, with this way i don't have to split walls, duplicate the walls with another name, wrapping the walls i check the interor or exterior materials and so one, see image attached... Edited on: Wed, Aug 13, 2008 at 4:06:19 PM
Edited on: Wed, Aug 13, 2008 at 4:24:33 PM
Now to solve this, you must use the "paint" tool, chose the material you want and pick in the face you want to aplly with that material... I think this is the most easy and quick way to solve this issue...
Edited on: Wed, Aug 13, 2008 at 4:26:11 PM
Hi, if you need more assistent (help) to do this tell me and i create a video for you....
5 Posts No Rating |
Man u are the bum ive not et tried it out im going to right now but i could not help be scream when i saw the image that u attached. Sorry bout yesterday nite. I lost internet conection if not i should have replied imidiately. Thanks again
5 Posts No Rating |
thanks bro u sure are one wiz kid. I used ur later sollution i applied a paint to the face, that solved it, but i would like to know how u made the sweep go round ur wall i need a little more details, thanks a lot agian. ur explanation was helpful, i guess ill try out ur method in future projects.
5 Posts No Rating |
thanks a lot i got it solved. but please as soon as u have time help me out with the proceedure for creating a sweep that goes round just like urs.
Yeah, you welcome, wait for the video...
Hi TITTO, this is the first of the video you want: http://screencast.com/t/sFDZssB1iN I post the other after a few minuts....
Edited on: Thu, Aug 14, 2008 at 4:01:45 PM
Hi Titto that's the second video: http://screencast.com/t/5plLdgni
Hi Titto that's the thirth video: http://screencast.com/t/TirLg33C
wall wrapping problems |
Wed, Mar 4, 2015 at 9:59:03 AM
wall layers not wrapping at curtain wall inserts! |
Fri, Mar 4, 2016 at 10:27:09 PM
wrapping of wall inserts |
Fri, Jul 14, 2006 at 5:13:19 PM
Wall wrapping |
Thu, Jun 17, 2004 at 6:15:30 AM
Wall Wrapping at Inserted Wall |
Thu, Aug 27, 2009 at 8:44:19 AM
Members: | 2115869 | Objects: | 23193 | Forum Posts: | 152301 | Job Listings: | 3 |
