63 Users Online (61 Members):
Forums >> Revit Building >> Technical Support >> Minimum Lineweighs
20 Posts No Rating |
I'm using Building 9. Is there anyway to set line weights for perspective views to less than .75?
sorry, that was meant to be less than 0.075.
![psymon Avatar](user_avatar/9799.jpg)
![3.5 Stars: 6 Votes](/images/stars_3.5.gif) |
do you mean version 9 or 2009? The only settings are under Settings > Line weights > perspective Line weights Version 2009 you must enter a value equal or greated than 0.025 (mm) I don't know if you mean inches????
It's version 9 that I'm on, and yes, it the perspective line weights (via settings>line weights) that I can't change to less than 0.075mm. Was hopeing there may be a way around this or a setting I could change that effects the default minimum.
Mass Floors with a Minimum Height/Clearance |
Wed, Apr 18, 2012 at 5:25:50 AM
Minimum width plugin window |
Fri, Sep 22, 2017 at 8:22:59 AM
What is the true Minimum machine spec for a BIM Engineer? |
Wed, Jul 2, 2014 at 8:32:51 AM
Minimum / Maximum Parameters |
Fri, Nov 3, 2006 at 2:07:45 PM
Why does the flexible duct disappear at minimum length? |
Sun, Jan 7, 2018 at 1:28:10 PM
Members: | 2022246 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
