77 Users Online (76 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Community >> The Studio >> Can you save linework?
Tue, Aug 12, 2008 at 1:46:33 PM | Can you save linework?
tinninttu
When using the linework tool on say interior elevations, is there any way to save it? Because i've noticed that if i do linework on a cabinet or something, and change the height or pull the view box back a little i have lost all linework. Do i have to wait to do linework until I am sure i have everything where i want it, or is there any way i can save it? Thanks a bunch
Stephanie
Tue, Aug 12, 2008 at 2:22:08 PM | Can you save linework?
3.5 Stars: 395 Votes
Not been asked this before but have seen that this is true.  I don't believe there is any way to save this information.
Tue, Aug 12, 2008 at 2:27:55 PM | Can you save linework?
tinninttu
ok, thanks for posting, appreciate it.
Tue, Aug 12, 2008 at 7:37:07 PM | Can you save linework?
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
I'm not sure if I am getting this. Are you using the linework tool as shown in the image attached? Using RAC 2009 I was able to place a base kitchen cabinet, create a new interior elevation view, and then use the linework tool to modify the cabinat line work. I used invisible lines, hidden lines and wide lines. Then I was able to move my elevation view in plan and stretch the elevation view crop region around without loosing my linework. I was also able to change the instance parameters and the family types and still retained the linework. Am I missing something? Linework is always saved until you set it back to 'by catagory'.
Linework tool issue
Mon, Sep 26, 2011 at 3:20:44 PM
Improving Linework in Sections & Elevations
Sun, Mar 30, 2008 at 12:30:48 AM
How to delete linework created by underlay
Tue, Jan 31, 2012 at 9:45:57 AM
Cant save, save as, print.......
Tue, Sep 10, 2019 at 6:24:44 PM
Linework on column woes
Fri, Apr 29, 2005 at 12:40:35 PM
Page generation time: 0.3432
