173 Users Online (172 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Glass Block Wall
Tue, Apr 19, 2005 at 11:18:39 PM | Glass Block Wall
Sofire7
How can I adjust the length of the Glass Block Wall that I downloaded off this site? Or should I just create my own and how would I go about it? (This particular glass block wall is 1500H x 1800W and has a 900W x 600H fixed glass window 450 from all sides if someone wants to make it for me?!). Ta. Sofire.
Wed, Apr 20, 2005 at 12:04:42 AM | RE: Glass Block Wall
Arnel Aguel
You can easily create a glass block material and apply to your wall. For you to start with open up the glass block material in your revit material library then disect it. You can adjust the subdivision size as per your liking then just add a surface pattern that will correspond to the size of your accurender material.
How to create a Glass Block Wall?
Thu, Mar 23, 2017 at 6:52:00 PM
13
Glass Block Wall
Wed, Feb 23, 2011 at 2:01:25 PM
Glass block
Sun, Jun 4, 2006 at 12:38:26 PM
glass block wall
Tue, Mar 2, 2004 at 9:49:53 PM
Glass block surface patterns: how to adjust?
Tue, Mar 27, 2007 at 10:56:02 AM
Page generation time: 1.0059
