106 Users Online (105 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Groups. Move partition walls, how?
Tue, Aug 12, 2008 at 1:15:45 PM | Groups. Move partition walls, how?
markuspirker
I have a partition layout that is a group. I want to move around partions inside the group.
Usually I apply a dimension to a partion, click on the partition and then the dimension becomes active and I can type in a value.
This does not work inside the group. I can dimension a partion but when I click on the refering partition, the dimension is not activiated, It is outside the group.
How can I controll the precise moving of partions inside the group? The temporay dimensions work most of the time but not always because they snap to refernces I don't need.
Is there a setting to put dimensions inside the group?
(REVIT 2009)
Tue, Aug 12, 2008 at 2:16:59 PM | Groups. Move partition walls, how?
3.5 Stars: 395 Votes
You are using a group because you have a lot of the same layout .... right?  If not - DON'T!
You have found one of the pains of using groups.  You can add lines outside the group first and then edit the group.
Tue, Aug 12, 2008 at 2:33:10 PM | Groups. Move partition walls, how?
bauhaus1919
bauhaus1919 Avatar
3.5 Stars: 9 Votes
The easiest way I use is with the temporary dimensions. Remember on those temporary diemsions, you can grab the square grips on the extension lines and drag them to whatever you want to set your distance by. They work like regular dimension witness lines that way.
Tue, Aug 12, 2008 at 3:08:45 PM | Groups. Move partition walls, how?
markuspirker
Grabbing the temporary dimensions and putting them where needed works. Thank you.
Partition walls [system family]
Wed, Dec 9, 2009 at 10:25:41 AM
curtain walls make like partition walls
Sun, Oct 26, 2008 at 9:23:37 AM
11
Partition Types
Wed, Jun 18, 2008 at 2:16:51 PM
Partition Types for Construction Drawings
Fri, Feb 8, 2013 at 3:32:02 AM
floor plan apearence for partition wall
Wed, Jun 2, 2010 at 7:25:37 AM
Page generation time: 0.8491
