Forums >> Revit Building >> Technical Support >> Problem aligning views on sheets
I seem to have lost my ability to snap wall sections all to the same level on the sheet. Also, my view titles won't snap either. Anyone seen this before?
LUNCH, i don't understant what do you mean? can you put some video or screenshot about this, man?
you know how when your putting views on sheets that model views (like sections) will snap to each other so that they lay across the page at the same levels? I've lost the snapping ability.
Problem is passed off to the local autodesk people. Will post if solution is found.
Hi LTR I believe that this may be to do with the snaps - when I turn all the snaps off I recreate your problem.
no, the exact problem is when you rotate a view on a sheet. take a couple of section views and put them on a sheet. then turn them 90 counterclockwise in the options bar. then snap them together. then see how far off they are.
Aligning views |
Thu, Mar 20, 2008 at 6:27:30 AM
Adding / Aligning Legends to multiple sheets |
Fri, Oct 17, 2014 at 9:03:43 AM
Aligning Dependent View across Sheets |
Wed, May 7, 2008 at 11:41:51 AM
Aligning of views! |
Wed, Sep 5, 2007 at 6:59:36 AM
Aligning Sheets (Titles, Viewports, ETC.) HELP! |
Tue, Mar 11, 2008 at 1:25:09 AM
Members: | 2104797 | Objects: | 23178 | Forum Posts: | 152306 | Job Listings: | 3 |
