72 Users Online (71 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> General Discussion >> Revit Project Management >> Storefront door problem...please help!
Mon, Aug 11, 2008 at 1:42:48 PM | Storefront door problem...please help!
cadpro78
cadpro78 Avatar
3 Stars: 2 Votes
Okay I have a question as to why the storefront single-glass door I added to this storefront assembly I made is appearing the way it is. (See attached picture of problem)
Anyone know how to solve this or maybe this happen? I added the "Curtain-wall: Storefront"  then placed the door through the load command.  Any help would be appreciated thanks!!
Tim McDougald
CHILDREY ROBINSON ASSOCIATES
1212 Kenilworth Avenue
Charlotte, NC  28204
Mon, Aug 11, 2008 at 2:03:13 PM | Storefront door problem...please help!
Belinski
4 Stars: 5 Votes
It looks like theres a problem with the family and its placement.
Mon, Aug 11, 2008 at 2:27:06 PM | Storefront door problem...please help!
4 Stars: 203 Votes
Hi edit the family and check if the Symbolic/model lines (opening, panel, swing... "projection"Winking are locked to the ref. planes....
Edited on: Mon, Aug 11, 2008 at 3:17:03 PM
Mon, Aug 11, 2008 at 2:43:32 PM | Storefront door problem...please help!
cadpro78
cadpro78 Avatar
3 Stars: 2 Votes
Thanks for your replay, but I can't find the location to check the model lines once I click on "Edit Family" for the door?
Tim McDougald
Charlotte, NC  28204
Mon, Aug 11, 2008 at 3:03:00 PM | Storefront door problem...please help!
4 Stars: 203 Votes
Hi, when you pick on the door and "edit Family", go to "Floor Plans-Ref. Levels" then you have the "Symbolic Lines-Panel (Projection) and the Plan Swing (projection)", when you pick in one of them  appears the locks like in the image attached, if any lock is "open" you must closed...
Mon, Aug 11, 2008 at 3:03:38 PM | Storefront door problem...please help!
lunchtrayrider
3.5 Stars: 7 Votes
i think your door swing lines are locked to the face of the wall in the family.
Storefront Wall needs Storefront Doors
Mon, Dec 3, 2007 at 8:58:52 AM
Storefront Door Editing
Fri, Jul 30, 2021 at 3:39:16 PM
HOW TO PUT A DOOR IN A STOREFRONT
Sat, Mar 21, 2009 at 4:38:51 PM
storefront doors in curtain wall
Mon, Mar 23, 2009 at 6:00:00 AM
Phasing for storefront system panel
Wed, May 18, 2011 at 7:44:36 AM
Page generation time: 0.8809
